Old 01-19-2013, 02:55 AM
Nojjan Nojjan is offline
All thumbs...
Rep: 30 Posts: 107
Parametric planing hull generator for Rhino
Hi there, I wrote this worksheet a while back and have been using it for some time, mainly when I need a quick start on a hull (for whatever reason) and I thought I should share it. It is simple but useful. Input in Excel, Copy resulting column, paste in Rhino, and you have a boat (or at least the start of a planing hull...).
Note three different base shapes at bottom tabs:
-Planing hull With chine flat
-Planing hull Without chine flat
-Planing hull With chine flat and Monohedron base
Enjoy! / Nojjan
Ps. only monohulls and it's metric, sorry.
Old 01-21-2013, 06:43 PM
CWTeebs CWTeebs is offline
USCG 3AE
Rep: 171 Posts: 202
Very cool!
Does the red in the spreadsheet mean user interaction is required?
Old 01-22-2013, 02:00 AM
All thumbs...
Rep: 30 Posts: 107
Red only visual aid
No special input at the red text. I used the red bold text to give myself some visual indication for next object (curve). The red at the bottom of the J-column is to remind myself which commands are used to create the surfaces.
Input is done in B4:B18, unless you want to change the sequence of course. / N
Old 01-22-2013, 11:03 AM
USCG 3AE
Rep: 171 Posts: 202
Well, I like it a lot, thank you very much for sharing!
Old 01-22-2013, 07:10 PM
quequen quequen is offline
Rep: 190 Posts: 240
Nice! thanks for sharing, thumbs up!
Old 01-23-2013, 05:32 AM
rwatson's Avatar
rwatson rwatson is offline
Rep: 1404 Posts: 3,040
I am confused. When you say "paste in Rhino", what does that mean ?
Old 01-23-2013, 08:56 AM
El_Guero El_Guero is offline
Rep: 70 Posts: 260
I am with RW.
I thought I would put in values and it would tell me if the values would produce a planing hull.
Old 01-23-2013, 10:39 AM
USCG 3AE
Rep: 171 Posts: 202
You enter the specified values and the Excel sheet computes the keel and chine curves for the family of planing hulls specified. The sheet then turns these into Rhino commands such that the mathematical curves can be turned into CAD geometry, in this case Rhino can loft the curves via the Sweep1 or Sweep2 commands. You quite literally do as Nojjan said: highlight column "J" of his rather nifty spreadsheet, go to any view in Rhino and paste. You get the result shown in the attached screenshot. You can further automate the geometry process by calling Rhino's kernel via VBA commands from Excel. There's also a very useful Rhino geometry manipulation code called Grasshopper, but I have not used it personally.
Old 01-25-2013, 06:10 AM
rwatson's Avatar
oh, you mean paste it into the command window.
the details make all the difference.
Old 01-25-2013, 09:05 AM
USCG 3AE
Rep: 171 Posts: 202
I pasted into the perspective viewport.
Old 01-25-2013, 04:52 PM
All thumbs...
Rep: 30 Posts: 107
Hi, to clarify, mark J3:128 in the excel sheet, press ctrl+c, start Rhino and activate any view and then hit ctrl+v, the code is then executed in sequence in Rhino's command run generating your specified geometry / N
Old 01-30-2013, 03:17 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 163
Nice routine. The only minor quibble I have with it is that the hull is oriented with Y up instaead of Z being up, but a simple rotation solves that.
Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) metin_mehel Software 11 10-11-2011 01:10 AM
parametric design fedemaranca Sailboats 2 06-13-2008 11:05 AM
research parametric design fedemaranca Boat Design 5 06-12-2008 04:32 PM
Displacement hull replace planing hull Fanie Powerboats 11 01-30-2008 07:51 PM
Parametric Study andy_uk Powerboats 3 08-16-2006 05:34 AM
