Do you use "Automatch" (or whatever the name is) to match the lines plan? By the way. Do you all get the same nice results matching a round bilge hull forms? It allways takes me a lot of hours to fair the stern and sternpost. Thanks a lot! |
| Easyly, by using contours and then generate a 2D-drawing. Terho |
| Elkano Welcome to the forum If you have defined the shell (as you would) then lines are very easily generated with automated scripts or even manually with the section command. There are also plugins that do this automatically. Cheers
| Thanks a lot Terho and MikeJohns. Cheers! |
| i can tell you about a software which can convert an image file to cad file(dxf) you can scan your paper first then you can convert into dxf file and you can import dxf to any cad software. here is the link: http://www.cadtool.net/image2cad.htm |
| Thanks pavel915 But that is not what I'm looking for. I must convert old paper hull lines plan to 3D faired surfaces. I wonder if there is any software that makes that work easier. Long time ago I tried to use "Automatch" but it was no-wotrhy Thanks!
__________________ Excuse my poor english.... |
| there is no easy way, all required some tweak and work |
| Elkano; if you have a lines plan in paper; then scan it; and make a dxf lines plan by image to cad software or by tracing on background image. then using the 2d lines plan you can make the hull very easily in rhino using loft or networksrf command. these are the minimum works you must have to do. |
Thanks again!
| Maxsurf vs Rhino which is easiest for building superstructures? | yades | Software | 11 | 01-15-2010 03:13 AM |
| Easiest (i.e. cheapest) way to build a raft + rafting disaster! | Spyder Ninja | Boatbuilding | 31 | 02-20-2009 09:58 PM |
| Cheapest and easiest building material | Mat-C | Materials | 36 | 08-20-2007 02:52 AM |
| Whats going on people | Littlebearcanoe | Boat Design | 2 | 09-07-2005 07:06 PM |
| Whats the best way to run my light? | Lil John16 | Electrical Systems | 2 | 06-06-2005 03:21 PM |
