Old 09-09-2009, 09:52 AM
stavrou2000 stavrou2000 is offline
Rep: 10 Posts: 24
Outflow Calculation In Autohydro
OK MY PROBLEM IS VERY DIFFICULT...
I WANT TO EXTRACT FROM THE AUTOHYDRO THE OUTFLOW CALCULATION ACCORDING TO MARPOL FOR A TANKER VESSEL. SO I NEED THE A RUN FILE. ANYONE CAN HELP ME?
FURTHER MORE I NEED SOMEONE TO HELP AND GUIDE ME ON HOW I CAN USE THE "DAMSTAB" FROM AUTOSHIP FOR TANKERS AND NOT FOR BULK CARRIERS.
THANKS IN ADVANCE
PS : MY PRIVATE EMAIL IS xarisstavrou@gmail.com
Old 09-09-2009, 12:42 PM
Martijn_vE's Avatar
Martijn_vE Martijn_vE is offline
Marine software developer
Rep: 401 Posts: 251
No need to shout......
Old 09-10-2009, 03:00 AM
Rep: 10 Posts: 24
hey martin i am in a very difficult position here.....i dont want to do all these calculation by the hand....i will finish the study in the next year...)))))
Old 09-10-2009, 06:31 AM
Martijn_vE's Avatar
Rep: 401 Posts: 251
Well you probably can solve it using Excel, but it will require a lot of programming.
Old 09-10-2009, 08:17 AM
Rep: 10 Posts: 24
Yes I Know..i Do It Right Now...but I Hope That Anyone Can Help Me With That Using Run File...cause I Am A Autohydro User But I Am Not So Specialized With The Macro Order....i Am Sure That Someone Have This Routin Coz I Saw In The Internet That Some Guys Have The Outflow.run But I Must Pay To Take It...
Anyway...thanks For The Intresting I Am Going To My Excle Files To Finish The Calculations..i Hope In This Year.....xaxaxa
Old 09-10-2009, 09:25 AM
Paul Kotzebue's Avatar
Paul Kotzebue Paul Kotzebue is offline
Rep: 272 Posts: 240
Why not write your own run file? If you can write an Excel spreadsheet to do the calculations, you should be able to write the run file yourself.
Paul R. Kotzebue, PE
www.pkboatplans.com
Old 09-10-2009, 11:47 AM
petlily petlily is offline
Rep: 10 Posts: 29
This is from GHS website. Not sure if it is applicable for autohydro;
New Oil Fuel Tank Protection Regulation OUTFLOW Compliance
OUTFLOW [(fuellist)] lsdraft [,loaddraft] command was added to report compliance with MARPOL 73/78 Annex 2 Regulation 12A protecting the given oil fuel tank list (default is all tanks containing "DIESEL OIL" or "FUEL OIL"). All provisions of reg 12A are verified except paragraphs 9 and 10 pertaining to piping valves and suction wells. The molded midship lightship draft is required; default summer load line draft is the LCF draft as currently loaded. Optional parameters:
/BOTtom:[fueltank[:area]],... - fuel tanks bordering the bottom shell with optional maximum horizontal projected area (reg 12A.11.5.3.3; default bottom tanks touch bottom shell using horizontal bounding rectangle area);
/CAPture:caplist - fuel tanks bounded below by non-oil tanks (reg 12A.11.5.4; by default a fuel tank may be captured by any tank not in fuellist which intersects its horizontal bounding rectangle with lower minimum and maximum vertical heights);
/HULL:name - hull part name (default is HULL or first displacer part);
/LENgth:len - vessel length (reg 12A.3.9; default is 96% waterplane length at 85% of least molded depth for deck edge);
/BReadth:br - vessel molded breadth (reg 12A.3.7; default is overall breadth);
/DEPth:dep - vessel molded depth (reg 12A.3.8; default is midship deck depth);
/SPGR[:density] - nominal specific gravity used instead of current fuel tank values (reg 12A.11.2.3; default is 1.0);
/PERM[ermeability] - nominal permeability used instead of current fuel tank values (reg 12A.11.2.4; default is 0.99);
/STOP - stops command processing when overall success or failure is determined;
/SKIP - skips consideration of geometry qualifications for closeness to shell;
/LOG[:file] - logs full calculation details to file (default is OUTFLOW.LOG).
Old 09-10-2009, 02:29 PM
Rep: 10 Posts: 24
to Paul Kotzebue....Hey man there is no run file for autohydro to do the outflow calculation.....on the other hand in the excel its not so easy...you have to do a lot of work before define the propabilidtic method....I think i wil try in the future to build a run file to do this specific job....
to petlily.....Following your post my friend this is not a formula...but just a routin...i want the heart of this routin.....
Thanks guys for your help...if you find anything further do not hesitate to contact me.....
Ps I want to say here that the autohydro have three basic disadvantages
1. the FSM : All the classification society wants the maximum free surface moments for the subject tank...but autohydro compute the MAXFSM for the specific heel and trim....it is correct but its not the wanted fsm
2.Damage Stability for tankers : All others programmes like NAPA compute by its self all the possible compination of the damage cases.....In autohydro you must do that by the hand
3.Some times autohydro compute wrong the MAXVCG...i had serious problems with the Lloyds and DNV last year.....
I use Autoship 5 years and maxsurf 8 years...i think the first one is more programmatistic....compare with the maxsurf
Thats from me....
Greetings from greece
Old 09-10-2009, 07:44 PM
Rep: 272 Posts: 240
I also had problems with incorrect AutoHydro MAXVCG's. A few years back I discovered AutoHydro floodable length is not accurate either.
I have never had any problems with GHS.
I hope you are successful in creating a run file. Once you get it to work properly, you can use it over and over again. Hopefully it will be worth all the extra effort in the end.
www.pkboatplans.com
Autohydro help Leron Software 7 08-20-2009 10:06 PM
problem in Autohydro saad Software 0 12-14-2008 05:30 AM
Help me in using autohydro!! same Software 4 02-01-2007 02:34 AM
AutoHydro netjaws Boat Design 0 01-07-2006 08:58 PM
cal in autohydro hello Software 5 03-04-2005 09:23 AM
