Old 03-02-2006, 09:31 AM
vinceUK vinceUK is offline
Rep: 34 Posts: 42
Open cockpit on rhino
Hy everybody, I just need a little tip on rhino. How would you do an open cockpit on rhino, that would cut both deck and transom. I've managed to do a box-shaped cockpit but do not know how to do an open one (type VO70,...). Thanks for your help
Old 03-02-2006, 03:30 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
If deck and transom are closed now (ia it is after a typically iges import?), you can make the cockpit sole and sides as surfaces, let them extend out in the open and the use it to trim both deck and transom. Alternativelye you could model the deck and transom with the openings in the first place.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-02-2006, 03:36 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
I don’t know Rhino that much but most cad have a trim command. Place cockpit on boat then trim out/off the bits you don’t want.
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
cockpit or pilothouse EASI54 Boat Design 17 09-05-2005 05:23 PM
Self-draining cockpit sdroberts Boat Design 0 08-30-2005 06:03 AM
Cockpit ergonomy? parloponti Education 4 06-29-2005 07:12 PM
Cockpit hatch drs3317 Boat Design 0 03-31-2005 07:51 PM
