Old 02-02-2007, 12:06 PM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
one thing about rhino
I need to find the weight and position of cg of the hull shell plates
so the wetted surface area and the position of the CG of hull surface will give the result.(wetted surface area*plate thickness will give me the plate volume)
now. I found that , rhino has a option analyze>massproperties>area and
analyze>massproperties>area centroid
will this give me the result I am wanting? I am a bit confused about that.
please make me clear about it ,,,, by your reply.
thanks.
Old 02-02-2007, 06:02 PM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Don't confuse wetted area with the whole hull.
For cg of the whole hull you can use the command AreaMoments.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 02-02-2007, 06:19 PM
Raggi_Thor's Avatar
It seems like the AreaCentroid is what you need, you ca select as many surfaces as you want.
Here is from a small boat:
Cumulative Area = 6.8288999 (+/- 1e-006) square meters for 5 surfaces
Cumulative Area Centroid = 2.387977,-3e-016,0.2387679 (+/- 3.6e-006,1.7e-006,5e-007) for 5 surfaces
This boat has the center of gravity 2.4 meter from the bow (2.387977).
Your boat (ship) is probably rotated, but you see what I mean.
Since I wasn't sure how this command works, I made a simple surface, a rectangle with one corner in 0,0,0. If you kow the answer it's easier to fihure out what Rhino calculates.
www.MBOATS.no
Old 02-03-2007, 12:30 AM
pavel915's Avatar
Rep: 154 Posts: 319
oh;;;;;;;; so this is a very good thing for estimating the many parst of the ship.
It can help us a lot for weight estimate.
Old 02-03-2007, 03:04 PM
Antisthenes Antisthenes is offline
Rep: 10 Posts: 16
use v4?
Is replacing and transom seal a do-it-yourself thing? JonEaton Sterndrives 12 10-11-2007 04:15 PM
Just build the darn thing. Scott Carter Boatbuilding 32 07-25-2007 09:38 PM
Swept back hull appendages. A thing of the past? xarax Sailboats 6 06-21-2006 12:19 PM
Best thing next to popcorn! Piannerionist0 Software 1 05-07-2006 08:12 AM
Oy vey is this thing on ? CgarciaDesign Open Discussion: All Things Boats & Boating 0 12-31-2004 02:42 AM
