Old 04-14-2006, 09:06 AM
wrabbit wrabbit is offline
Rep: 10 Posts: 2
Offsets
Hi,
I am using freeship as design software (www.freeship.org). I don't really understand how to use offsets to define a hull. Is there any beginners information on offsets?
Thanks
Old 04-14-2006, 09:25 AM
DanishBagger's Avatar
DanishBagger DanishBagger is offline
Never Again
Rep: 523 Posts: 1,543
Offsets are halfwidths from the centerline, and heights on those hlafwidths from a baseline.
Chapelle's "Boatbuilding" has some good info on lofting (i.e. using offsets to define a hull, although not with a computer), there's a couple of other good books on the subject out there, "Lofting", but I can't remember the name of the author on that one (Valdez?).
Edit: It's sort of an X/Y diagramme, where the x (horisontal) is the baseline, and y (vertical) is the center line.
Andre
Old 04-14-2006, 09:34 AM
Never Again
Ouch, I think I forgot to mention something rather important:
Each station (a station is just a defined distance from the stem or transom of the boat), has it's own offsets, naturally, unless it's a pipe, and by defining the distance from the end, and then the distance from respectively the base line and the centerline you get a series of points you can then connect.
I did it the analogue way, with bendable sticks, but it's the same idea.
You have to subtract the thickness (scantlings) of the planks/glassfibre and so forth, though.
Old 04-14-2006, 10:36 AM
Rep: 593 Posts: 2,054
Here's the book to which the Bagger referred:
http://tinyurl.com/rkwzr
It's called: Lofting by Allan H. Vaitses
Chris Ostlind
Lunada Design
Old 04-14-2006, 10:42 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,728
Offsets define the hull thru an X,Y,Z coordinate system. X is defined as your station points from the bow or stern along the DWL. Y is the height coordinate when looking at the profile and Z is the beam coordinate. The beam is expressed as a half width...it assumes that the hull is symmetrical along the centerline. You can also use this system for plotting the lines of a developed panel...tho usually you only use X and Y as the panel is assumed to by 2 dimensional. Stitch and glue uses this method extensively, as the panels are pre-shaped to give the correct shape to the hull.
Steve
Chris, you must type faster than me
Old 04-14-2006, 10:53 AM
Never Again
Chris Ostlind
Lunada Design
Yup, that's the one
Old 04-17-2006, 03:12 AM
Rep: 10 Posts: 2
thank you
thank you all for your help in such a short time frame!!!!
Old 04-17-2006, 06:53 AM
Never Again
You're welcome.
As a p.s. I found it really funny lofting in real size. It's amazing. No "black art" to it as some will have you think, it's just a matter of being precise. To see the lines take shape from a few numbers is amazing. I think I could build another (simple) boat, just to have my fun with laying down the lines. I really enjoyed that part
Good luck.
Offsets to PC program marcelo61 Software 2 01-22-2006 02:36 PM
Table of offsets from Rhino maksic Software 5 10-12-2005 11:07 AM
table of offsets aqua_ambulat Boat Design 2 09-17-2005 08:07 AM
Hull Offsets Alixander Beck Software 0 09-06-2005 03:52 PM
Table off Offsets? Guest Fiberglass and Composite Boat Building 1 10-03-2004 09:14 AM
