| NURBS issue Guys, Does anyone know how to mathematically represent NURBS having the passing points and NOT the control points? Nothing much in dedicated books such as Les Piegl etc... Cheers |
| make a table using points and project the points on the surface. then give points the form you want. finally product your surface using this edited points. i think it is the easy way to use passing points. there isn't any simple command for it. |
| Mate, u misunderstood me: I need the mathematical representation, I mean equations bla bla. Your approach is not the analytical one. Thanks anyway |
| Suhoi If I knew what you meant by passing points I might be able to help, but I have never heard the term before. Can you clarify what you mean.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| A parameteric curve can be defined by either Control Points (i.e., those that can define the flexibility of the curve in addition to their weigths) and the Passing Points (i.e., those that lay on the curve, and sometimes called crossing points). Hope this helps, Regards, S |
| I assume that your code has something such as [N]{b} = {p} [N] would be the basis functions needed to produce nurbs, and {b} are the "ducks" or whatever you want to call the weights to produce a line passing through points in {p}. You should be able to invert N to solve for the points. However, N is not square, therefore: N b = p N^t N b = N^t p b = (N^t N )^(-1) N^t p I believe that this should work. You may need to put in some boundary conditions so that it is not ill-conditioned. Also, someone let me know if this is incorrect! I may be way off base here. -Jon |
| Jon You are exactly correct, this is what surface fitting programs such as our own Prefit program do. If the number of control points is equal to the number of data points the fit is exact but prone to geometric instability, if there are fewer control points than data points the result is a least squares fit. The hard part of the problem is determining the isoparametric values for the data points. If these values are known precisely in advance the results are good, however estimating them is extemely difficult. Andrew
| NURBS and Polynomial Basis Functions | Tim B | Software | 15 | 07-11-2005 04:36 AM |
| NURBS surface | suhoi | Software | 0 | 07-06-2005 03:21 PM |
| 454 jet boat- power issue | jman | Powerboats | 2 | 06-03-2005 02:08 PM |
| pilot 3D-does it only use Nurbs surfaces? | L.DOSSO | Software | 3 | 11-13-2004 06:27 AM |
| Planing issue, looking for direction. | hookdup | Powerboats | 5 | 09-07-2004 05:19 PM |
