Old 08-15-2005, 10:36 PM
pdavidson pdavidson is offline
Rep: 10 Posts: 3
newbie - Rhino - table of offsets
I have a table of offsets and the hull lines - is it possible to enter into rhino to produce a hull? Are there better programs to enter the table into to produce a computer model of a hull?
Thanks.
Old 08-16-2005, 06:06 AM
JEM JEM is offline
Rep: 38 Posts: 291
yep.
I tried once before in Rhino and what I discovered was that the offsets weren't completely fair. Rhino is a great tool to check for that.
Matt - JEM Watercraft
Old 08-16-2005, 06:35 AM
Tim B Tim B is offline
Rep: 763 Posts: 1,384
You'd be hard-pressed to find a better system than Rhino.
Breifly,
1) Load the offsets into rhino (either using the point input format from a text file ( as x,y,z ) or by hand).
2) Establish whether the matrix of control points is correct (ie, there is the same number of control points at each section) If so go to 3. If not, go to 4.
3) Use the surface from points tool (SrfPtGrid) and then follow the instructions.
4) Create curves through each section of points (this is easiest to visualise). Use the Loft command (or create curves for sheer and keel and use sweep2) to build a surface from all the curves.
5) Now the hull just needs fairing I use the Analysis tools for this.
Good Luck,
Tim B
Old 08-27-2005, 05:37 PM
chandler chandler is offline
Rep: 16 Posts: 378
Tim,
Does all that work in the demo version?
Old 08-29-2005, 08:44 AM
Should do, don't be afraid to use the Rhino Command Line :-)
Tim B.
Old 08-29-2005, 11:14 AM
ludesign ludesign is offline
Rep: 54 Posts: 177
Thanks.
TouchCAD also enables you to import points in TAB format, combine the points to curves and loft them into surfaces.
It also enables you to quickly and easily re-distribute such imported points more evenly along a curve and increase/reduce the number of controls parametrically. This substantially reduces the rather messy curves and tensions created by such an import, caused by points typically coming in fairly unevenly distributed in distance along the curves.
Claes Lundstrom
Old 08-29-2005, 12:38 PM
pro_user pro_user is offline
Rep: 10 Posts: 15
There is buildin function in SeaSolution to import offset table.
You can also control deviations of these points from your surface.
Look at www.seasolution.com
Table of Offsets for FFG-7 netjaws Boat Design 1 02-12-2011 02:31 AM
table of offsets aqua_ambulat Boat Design 2 09-17-2005 08:07 AM
software design question for Rhino Newbie pdavidson Software 8 02-28-2005 12:04 AM
Input from a table of offsets johnbeavis Software 2 08-18-2004 10:11 PM
Rhino Newbie Act Too... jprev Software 17 02-19-2004 01:30 PM
