Old 08-07-2010, 02:38 AM
crboats crboats is offline
Rep: 10 Posts: 2
Newbie Multisurf Question
Hi, I'm learning Multisurf and have a quick question. When I select a point, it is not showing any properties in the properties dialog box. I've had this happen on two models, although I've made a couple other models where everything was fine. When I do a query extents, the points are showing, with coordinates, etc, so I know the info is in the model... but in the dialog box, the spaces that normally have info are blank. I can draw in the model, but can't edit co-ordinates from the dialog box. I'm sure I'm overlooking something simple. Any help?
Question From A Newbie muddin redneck Open Discussion: All Things Boats & Boating 10 08-14-2009 11:39 PM
Question about stability(newbie) turbo2 Stability 6 08-19-2008 05:25 PM
Newbie here with newbie question. Marine plywood or plywood? photojunky Wooden Boat Building and Restoration 30 07-23-2007 05:41 AM
Newbie Question Scottlaf Fiberglass and Composite Boat Building 2 11-10-2006 05:37 PM
newbie with a question wolter9 Fiberglass and Composite Boat Building 6 07-01-2006 05:41 PM
