| newbie:I just want to type in offsets and see model ?? which is the best program to do this with out having to spend a week working through a tutorial . I have several sets of offsets of the same boat and want to observe the difference,check the fairness..... maybe much later ......... see it in 3D any suggestions ?? many thanks |
| Freeship Plus! |
| importing offsets I have made a ASCII txt file of offsets but when I try and import it into Delftship I get "Invalid Numeric input" message. I have the offsets in imperial 6.10.4, 6.9.2 ,5.9.7, ect ect, should they be written 6' 10'' 4/8 or some thing ??? contour lines ??? is Delftship referring to butts or diagonals ???? plan drawn in 1927 so different terms I guess. do I open a new project first ,set the longitudinal and vertical numbers ,length,beam and draft,units , create a model then import the offset txt file into it ????? nothing seems to work ?? |
| Delftship allows to import a "table of offsets" Produce them in Excel and save them as .txt, then import. There is a description in the tutorial. Do´nt ask me about details, I have no idea. Regards Richard |
the tutorial gives no mention how imperial measurements should be written.An important detain I would have thought . |
| I agree, but I have forgotten howto.... What I remember, there was exactly that question answered a few weeks ago here by Martijn, the developer of the software! Try to use the search function in the "software" forum part to find it! Regards Richard |
| if you have autocad, you can simply make a lines plan by the offset table and then make a model in Rhino by importing the lines plan to rhino, you can make the 2d lines plan in rhino also,
__________________ Md. Al-Amin Pavel http://www.paveldesign.tk "A question that sometimes drives me hazy, am i or are the others crazy?" Albert Einstein |
| Make it a simple way! Do a new model of any size, then export the offset table and have a look at the figures! That will tell you howto! Right? Regards Richard |
| yes maybe i could but then I would have yet another software program... !! I have so many already !! and I probably would not know how to use that one properly as well ,Deftlship is capable of doing everything I want if only I can understand the instructions !!! |
| Can anyone tell me what model, make, or type this boat is? | Zyis | Boat Design | 7 | 02-06-2008 02:32 PM |
| Newbie here with newbie question. Marine plywood or plywood? | photojunky | Wooden Boat Building and Restoration | 30 | 07-23-2007 05:41 AM |
| Borg Warner Velvet Drive Model 72c Current Model | DAVID HOSEGOOD | Diesel Engines | 1 | 12-27-2006 12:30 AM |
| Offsets | wrabbit | Software | 7 | 04-17-2006 05:53 AM |
| newbie - Rhino - table of offsets | pdavidson | Software | 6 | 08-29-2005 11:38 AM |
