  #31
Old 01-09-2013, 10:38 PM
DCockey DCockey is offline
Engineer
Rep: 1337 Posts: 2,411
Originally Posted by Ad Hoc View Post
You may find these up your alley then:
"Application of a real-coded genetic algorithm for the fitting of a ship hull surface through a single non-uniform B-spline surface", Le T-H., Kim D-J.
JMST Vol 16, No.2 2011.
and
"Surface intersection in geometric modeling of ship hulls", Ventura M., Guedes Soares C.,
JMST, Vol 17, No.1 2012.
Thanks for the suggestions.
John Letcher has promoted his "relational geometry" system as better at dealing with surface intersections. I'm curious to see what Ventura and Guedes discuss.
David Cockey
  #32
Old 01-10-2013, 03:44 AM
Mikko Brummer Mikko Brummer is offline
Rep: 211 Posts: 256
Originally Posted by fcfc View Post
Seems current trend:
See www.orc.org/minutes/ITC%202012.pdf , I a waiting for ORC VPP2013 documentation to be published to learn more.
Seems they no longer use delft series upright with a bunch of parameters. Only a dynamic waterline length, LVR (DLR the other way), and BTR (beam/dratft ratio). And they use heeled hull parameters, not uprigh hull parameters with heel correction.
Thanks... looks promising. It would appear that the new VPP is also allowing for leeway as an independent variable, although the document is not very clear about it (or anything else ;-). Anyway, leeway needs to be recalculated during every iteration loop for good results. The effective lenght calculation will certainly be better than the old one.
Mikko Brummer
WB-Sails www.wb-sails.fi
  #33
Old 01-10-2013, 03:46 AM
Rep: 211 Posts: 256
BTW, does anyone know how LSM (second moment length) are computed ?
There are some clues on page 21 chapter 4.2.2.4. http://www.orc.org/rules/ORC%20VPP%2...ion%202012.pdf
What I am missing is where is zero x stem or stern, and what unit (meter, feet).
And how is LSM0 is computed. Is it a recursive computation, since depth correction for section does include LSM0 term ?
Thanks.
Joakim could possibly comment on this?
Mikko Brummer
  #34
Old 01-10-2013, 03:49 AM
Rep: 211 Posts: 256
Originally Posted by Remmlinger View Post
If the updated version of UliLines with more control over the topsides at the bow is of any help to you, I can try to speed up my work and release the update asap.
Uli
Thank you Uli - the Dehler 33 bow now looks good!
Mikko Brummer
  #35
Old 02-01-2013, 02:19 PM
Remmlinger Remmlinger is offline
engineer
Rep: 134 Posts: 87
UliLines_4.2
There is a new version 4.2 with better fairing and more control.
The user's manual can be downloaded at
http://www.remmlinger.com/UliLines.html
roll prediction NavArch007 Boat Design 1 06-12-2010 07:10 AM
Very high speed prediction fede Boat Design 17 05-31-2009 09:25 PM
Velocity prediction? Mohan Pakkurti Boat Design 2 02-08-2007 03:30 AM
Velocity prediction program - Hamid Amini320 Dutch Peter Software 2 02-23-2005 09:33 AM
Performance prediction ? fcfc Boat Design 1 10-29-2004 10:09 AM
