Hmm... I've never seen it do that. It almost looks like the DXF files are corrupted. Try opening the DXF file in Notepad. It should look something like this... 0 SECTION 2 ENTITIES 0 POLYLINE 8 Layer 0 62 94 66 1 70 16 71 13 72 9 0 VERTEX 8 Layer 0 10 0.0 20 1.2084 30 2.4833 70 64 0 VERTEX 8 Layer 0 10 5.9219 20 1.2016 30 2.4901 70 64 0... The program looks for the keywords... VERTEX, POLYLINE, SEQEND and 3DFACE. I've attached the two data files again in case they were corrupted somehow.
__________________ Inquisitor Rocket Scientist or Space Cadet... you decide! |
| Just a thought... Does Greek use a comma (,) in a floating point number. I.E.... PI = 3,14159 or PI = 3.14159 If so, try exporting a hull out of DelftShip using the DXF 3D options and try loading it in Flotsam. If that doesn't work, upload a DXF file you have exported and let me see it. Thanks for your help. I would want it to work in Greek too. ![]()
| Its Greek to me... You're 50000 clue help me solve it. I re-created it! Yes, its your regional settings. But you shouldn't have to change it... The DXF files in the Tutorial exported by me here in the U.S.A. use "." for decimal seperator. If you edit the DXF files supplied, and do a global replace of "." with "," and save them, you should work correctly. I'm assuming that if you export your own DXF files in Greek and import them into Flotsam, you will also be fine. If not, I'll need to add some code to be able to handle both conditions. Please let me know.
| IT is interenting ,Can i test it ? |
| The truly interesting part is that you missed the free download link above. Check Here Or if there is such a concept as interenting in your country, I can say I'm truly sorry. I don't charge a rent for international copies... its free to people in China too. Unfortunately, being a handicapped (only know one language) American it may have some language issues with Chinese. As we know it couldn't handle Greek flawlessly. Chinese is Greek to me also! Good luck
| No sunshine... Not that I'm looking for praise... but, I am wondering... To this point, I haven't even heard if ANYONE has successfully done the tutorial. Does Flotsam have any merit or is this functionality already common in some other program(s)? Is it too hard to use? Have you found an issue? Has it helped you with a boat design? Do you have a suggestion?... I am wondering if I wasted my time putting a user interface on it for others to use. Will I upload an updated Flotsam? Will I put another program out on another design aspect or just keep the development mules for myself? If you'd rather not go public with a question or a statement... by all means... send a PM.
| Well... Imperially handicapped, I guess. At least there is one person using it... and found a bug. It seems I had a metric conversion calculation wrong. Thanks Fabrizio! Fixes/Enhancements (1) I've fixed the metric bug. (2) Have added some logic to help some converging issues. When you start trying to fly a hull (say a catamaran) sometimes the conversion gets into an infinite loop. The additions help re-focus the conversion and let you know its going on... so you can stop it yourself. Typically it means the boat was going to tip over anyway. So back off on the loads and try again! ![]() Note: The old version at the top of the thread is 1.0.0.1. This one is 1.1.0.0
| I downloaded the file and it installed fine. and i import the dxf file add the force,unto here is ok when i click analysis , the flotsam analysis is always run run run run …… i think it is too many attempts made for theis increment . |
| Tech support... The troubles you are having... is it in running the tutorial or using your own DXF files? If it is on your own files, send the DXF and FLT files to me either as an attachment here in the forum or as a private message and I'll take a look.
| Hydrostatic Data from Rhino 3.0 | Kirkos64 | Software | 0 | 12-20-2009 07:09 AM |
| Hydrostatic Properties at certain heel angle in Autohydro | petlily | Software | 2 | 11-23-2009 08:33 AM |
| Submarine Stability and Hydrostatic Calculations | gkhan61 | Software | 4 | 11-21-2009 06:10 PM |
| Help!!! Regarding with the Ship's Hydrostatic Calculation... | kilbysg | Boat Design | 0 | 04-10-2008 09:12 PM |
| hydrostatic in rhino 3 | Ahmed Wahab | Software | 7 | 12-27-2007 03:02 PM |
