| New freeware jSDN 2.0a A new version of the jSDN has been released, and can be found at: http://www.jsdn.es The new version includes digitally signed design files, a feature that allows files saved with the PRO version to activate all PRO functionalities on the FREE version. All sample files includes in the download are signed, which allows any user to explore all the possibilities of jSDN. When signed files are saved with the FREE version, the digital signature is lost. jSDN 2.0a Release Notes (Oct 30, 2009) * Improved overall stability * Updated VPP models and solvers * Improved GUI for LPP and VPP modules * Use of background images in several design screens * Digitally signed design files Best regards, Humberto Martinez
__________________ ------------------------------------ Humberto Martínez Barberá jSDN Yacht Design Software |
| java 3d problem installing jsdn is not enough. java 3d must be loaded, how ever it is very hard and complex procedure ![]() |
| use the installer instead of the binary. |
| Could you please 'print screen' the location of installation button? I am sorry. I really did not understand where can I load by installer. Thank you |
| Step 1: go to downloads (left hand side) of the jsdn page. Step 2: click on Java 3D software link Step 3: click on the + sign beside Java 3D™ 1.5.1 API Step 4: click on Download Java 3D 1.5.1 Software Step 5: select your operating system, check the box and click continue. Step 6: click java3d-1_5_1-windows-i586.exe or the exe for your operating system. It will download. Step 7: install it...follow the instructions (next, next, finish...whatever.) |
| I'm running Mac OS X 10.6.2 on my new Powerbook with 3.06 GHz Intel Core 2 Duo with 4GB RAM. I downloaded, and installed, and started each of the programs (jSDN Designer, Hydro, and Performance). All seem to "work" in that they all start, load a complete design for a sailboat. Looks very good! But I can't figure out how to use jSDN to design a boat. Are any tutorial documents available? Perfectly OK if they are draft versions, incomplete, and so on. I am willing to provide feedback on the tutorial, if that would encourage the release of the document!
__________________ David Smyth, Rocket Scientist |
| I am still preparing the documentation. I have a partial manual (which I include here), and a tutorial. The last one is in Spanish, and I am traslating it into English. I hope to release it during Eastern.
| I have followed instruction and succesfuly installed java 3d. How ever when I started the program it raises an error message " java 3d library not found" Thank you very much. |
| Can you give us some more information: operating system version (10.5.x, 10.6.x, etc) and java virtual machine version. You can access the first one in the Apple menu (about this mac) and the second in the Java Preferences (Utilities folder inside Applications folder). If you capture the Java Preferences panel, it could help.
| windows xp media center edition vers 2002 service pack 2 -------------------- Java Version 1.6.0_18 from Sun Microsystems Inc. I realy want to use this program. Thank you for your assistance. |
| Humberto, this is really nice! Edits to manual: Page 4 "Visibility. In order top help" should be "Visibility. In order to help" "Editability. ... thus disallowing the edition of" should be "Editability. ... thus disallowing the editing of" "Type/Subtype. This" should be "Type/Subtype. These" Near bottom of page: "(be them free" should be simply "(free" Page 5, paragraph starting with "Edited" "In this state the changed are" should be "In the state the changed value is" "the Intro key" should be "the Enter key" Page 5, paragraph starting with "Error" "if the users types" should be "if the user types" More to come. But as you can see, its already in very good shape, is very readable, and almost perfectly edited. Thanks very much!!!! I'll give you more feedback as I use it.
Humberto
| Humberto what about my problem? Thank you |
| Humberto, your English is very good! I've gotton a bit further, and noticed just two more minor edits. I bet if I gave you one of my papers, you'd find as many small errors! Just barely starting to use the tool, it sure seems easier than Rhino, but I'll give better feedback as I get along. Again, thanks, its really nice software!
In a typical windows XP installation, in Program Files you get a Java folder. Inside it there may be many things, typically one folder for each installed java virtual machine. You should java a jre6 or jdk6 folder at least. There are several ways to solve your problem. My advice is that you remove all the folders but the most recent one (i.e. jre6), and then reinstall java 3D. This should work with no pain. In case java screws up, you just reinstall java (this should not occur, it is just in case). I hope this helps, Humberto
| New software jSDN | Humberto | Software | 44 | 04-17-2009 02:07 AM |
| Jsdn - Yacht design Vpp ?? | DuncanG | Software | 6 | 06-12-2008 06:02 AM |
| Maritime freeware | D'ARTOIS | Boat Design | 1 | 02-28-2005 01:43 PM |
| Using hull design freeware + CAD | Slowmo | Software | 3 | 09-09-2004 08:27 AM |
| More 'freeware' drawings... PLUTO800 | Alik | Boat Design | 2 | 10-15-2003 05:35 PM |
