Old 04-12-2005, 01:29 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
My hands get cold
Sitting at my computer, my hands get cold and my fingers won't work right, and I can't...CAD...properly. Does anybody have any tips on this?
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 04-12-2005, 01:52 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 485
Try to keep the mouse on the table as near your bellybutton as possible. So the mouse between you and the keyboard at about 30-45 degrees. It takes a little while until you get used to move the cursor properly, but it pays.
I have used a mouse or a digital tablet more than 20 years and I had much trouble with my cold fingers and aching shoulder, but after I changed the mouse near my stomack, these symptoms eased up.
Old 04-12-2005, 04:30 PM
RThompson RThompson is offline
Rep: 116 Posts: 141
another thought I'v had re. ergonomics: (maybe not really related to cold hands)
How about an adjustable height desk?
Here's how it goes:
basically a normal computer/work desk, but with a big lever on the side. (kind of like a lazy boy)
So, one can work sitting on their normal chair for a few hours, then when the novelty wears off and the back/shoulder/neck/etc complains one can pull on the lever and the spring loaded mechanism will lift the desk to a standing or drafting stool height.
Rob
Old 04-12-2005, 07:40 PM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
Cure: be more time efficient. Sure, easy for me. If there is any bar or ledge that the bottom of your fore arm touchs or rests on , you will start to cut off circulation only in that hand. Remove the ledge.
Old 04-13-2005, 09:55 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
clap your hands or turn the heat high and think of the spring that is in sight
Old 04-13-2005, 10:16 AM
Danielsan's Avatar
Danielsan Danielsan is offline
Amateur designer-builder?
Rep: 10 Posts: 229
get yourself an ergonomic mousepad? with a silicon hump implanted? I use a nice thing called a spaceball 4000 but it is only used for moving, rotating parts and repetitive functions not for the drawing itself!
greetz,
to warm up your fingers might use a hammer and hammer on them this will warm them up, but it won't do for the good working of the fingers
Daniel Peeters
Old 04-14-2005, 02:10 PM
Hans Friedel Hans Friedel is offline
Rep: 10 Posts: 115
Use some sort of wrist suport
http://www.transcriptiongear.com/TG_Store/WH.html
A space mouse is also a good thing
Try to write as many comands you can.
Personaly I tries to exersice as much as possible. I paddle 2-3 times a week. But it is important that you should not have any pain when you exersice. If you have see a doctor
Hans
Old 04-14-2005, 02:18 PM
flame flame is offline
Rep: 10 Posts: 18
Hi
- You may want to adjust the mouse senitivity in your System Tray
- Have you ever tried a trackball instead of a mouse? You can use it when you wear gloves with tips cut off
- I agree with Hans, type much
- enter dummy points, lines and circles to serve you as reference points, and make much use of the various snap-to-reference function
Cheers
Mike
http://www.dauda.at
Wer seinen Hafen nicht kennt, für den weht kein günstiger Wind
Old 04-15-2005, 09:59 AM
Arrowmarine Arrowmarine is offline
Member
Rep: 10 Posts: 107
Ummmmm....... Move out of Canada? :-) Just kidding J.D.
Old 04-15-2005, 10:39 AM
stevel stevel is offline
Lost at sea
Rep: 15 Posts: 118
I was waiting for that one
I was actually going to be more specific by suggesting Florida.
Old 04-25-2005, 09:36 AM
carlg carlg is offline
Rep: 10 Posts: 7
I had the same problem and also had some pain in my wrist until a friend recommended a Contour Mouse. They come in a number of sizes to fit various hand sizes and also can be ordered left-handed. contourdesigns.com.
Keep the mouse low and don't let your wrist rest on the table.
Old 04-25-2005, 12:34 PM
CgarciaDesign's Avatar
CgarciaDesign CgarciaDesign is offline
Rep: 10 Posts: 53
Blow on them...that'll get them HoT. =)
www.coroflot.com/cgarciadesign
Old 04-26-2005, 12:30 AM
htom htom is offline
Rep: 10 Posts: 6
Have your thyroid checked.
Old 04-26-2005, 07:09 AM
cgorton cgorton is offline
Rep: 10 Posts: 50
Or, get a heated mouse.
http://www.theheatedmouse.com/
I thought about developing this idea until I searched for it and found that someone already had!
Old 04-27-2005, 03:38 PM
Semi-Newbie Posts Often
Rep: 10 Posts: 857
That's a cool idea. Nice, heated, massaging mouse would be better though...
Signed-
mackid068
_________
Sailing (n.) The art
=/\= A sailing Trekkie!=/\=
Strip planking / Cold molded ? fcfc Wooden Boat Building and Restoration 22 05-19-2005 08:55 PM
Cold Molding Advice stuart Wooden Boat Building and Restoration 17 01-16-2005 11:39 AM
Wood Cold Molded Epoxy/Composite Builders winap Wooden Boat Building and Restoration 6 07-23-2004 07:02 AM
cold mold VS Infusion>>strength/weight/cost compwest boats Materials 0 03-11-2004 11:23 AM
cold galvanized floors Boatbuilding 3 02-16-2003 03:31 PM
