| Moving multiple control points in FreeShip How can i move multiple control points at the same time in FreeSchip. I can select more then one with the control key but am unable to move them. |
| If you want all points to line up (for instance, if you want to move all points to the centerline) just select your points, then enter new values in the coordinates dialog box that appears on the screen. If you want to offset a group of points, relative to their initial locations, select the ones you want, click Transform --> Move and enter offset values for the X, Y and Z axes in the "Translation vector" box. |
| Dynamic moving Thanks Bruce, Is there a way to move a group of points dynamically, by moving you mouse? |
| You can also select the edge, go to edge menu and extrude the edge in the direction that you want |
| Need info on moving my boat to Montego Bay | JaMako | Open Discussion: All Things Boats & Boating | 2 | 04-04-2006 07:28 PM |
| Moving transom - making 10' out of 15' :) | glastront156 | Fiberglass and Composite Boat Building | 13 | 02-08-2006 11:12 AM |
| Moving weight to the bow during a race | Cliff Ruckstuhl | Software | 1 | 09-18-2005 08:09 AM |
| Sailing efficiency: % or multiple of windspeed | Doug Lord | Sailboats | 7 | 04-24-2005 05:14 PM |
| Using multiple bulbous bows as blocks? | 8knots | Software | 3 | 04-22-2003 06:27 AM |
