Old 12-30-2016, 02:02 AM
mrjo mrjo is offline
Rep: 10 Posts: 22
modifying freeship dxf in Turbocad??
HI I have imported dxf file of stations from Freeship into TCad but I have not been able to work out how to modify it in a controllable manner.
Can anyone help out with the correct procedure. I have V21 platinum pro so current program, but I haven't used it before, I can draw basic new objects, to start all I want to do is put cutouts in the stations for stringers.
Thanks in advance
Jo
Old 12-31-2016, 11:34 AM
alan craig alan craig is offline
Rep: 14 Posts: 83
You will probably get more help on a Turbocad user forum. I bought Tcad for Mac and it would not even create or read dxf files until an update came out.
Old 12-31-2016, 09:24 PM
Rep: 10 Posts: 22
Freeship DXF modifying in TCad HELP still needed
Thanks Alan,
I have posted on TC forum but no love there yet.
Anyone else with ideas?
Regards Jo
Old 01-07-2017, 12:53 AM
SukiSolo SukiSolo is offline
Rep: 271 Posts: 1,268
I'm not that familiar with Freeship, but if you get an option on the 'type' of DXF file for export you should try setting it to an older type ie Rel 14 or earlier. Note that up to Acad Rel 12 (Rel 12 DXF too) ellipses were not 'true# with a rho value of 0.41 which is the standard ellipse from most other decent CAD systems.
Maybe you could also try Intellicad if it's still around? TCad is a bit too basic for my personal requirements, although I have tried it - ages ago.
Old 01-07-2017, 03:48 PM
Rep: 10 Posts: 22
Hi Suki
thanks for the reply, no options for type of dxf export, that isn't an issue as I have sent it to designer with ACad that could modify it no probs, The TC version I have is a full 3D capable and I wouldn't call it basic, RRP $1400.
I need someone who uses Tcad and can give a few pointers on how to modify the dxf files, starting with the basics.
Cheers Jo
running v21 Plat Pro
Absolutely new to Rhino - modifying imported DXF rwatson Software 5 05-16-2012
06:29 AM
Turbocad just spat on me for the last time! LP Software 17 02-16-2012
08:40 PM
Printing Freeship .dxf output to lifesize plan? merry maid Software 2 07-19-2010
09:23 PM
Import Linesplan DXF to FREESHIP? internetturk Software 18 10-13-2006
04:22 AM
TurboCAD elcapitan Software 2 01-02-2006
01:26 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
