| modelling using maxsurf Hi, i need help on how to create the fwd part of ship, example like bulwark. i don't have any marker point at the position. if i add surface, then how to make it tilt to become a perfect shape of hull? |
| Bam yat create a new surface then use the bond surface command with the “strict tangency”. This enables the two surfaces to act as one. |
| Hi frienddd hi friend im alvaro from Peru. do you have some tutorial to learn to use a design i Maxsurf. my msn is alvarocotaquispe@gmail.com ill thank to you so much. |
| Thank you bhnautika. |
| A good place to start to learn http://www.formsys.com/maxsurf/webinars |
| Maxsurf - modelling a skeg which goes tangentially into the hull | ldigas | Software | 7 | 02-16-2011 11:36 PM |
| Maxsurf - seeking advice on modelling approach | ldigas | Software | 8 | 02-14-2011 09:34 AM |
| Modelling? | stonster | Wooden Boat Building and Restoration | 7 | 07-21-2010 03:45 PM |
| Modelling in Maxsurf with existing lines plan | squivo | Software | 1 | 03-07-2006 03:35 AM |
| AC yacht modelling accurately on Maxsurf?? | ac4ever70 | Software | 2 | 11-24-2003 08:48 AM |
