Old 07-27-2009, 08:20 AM
jozo_bozo jozo_bozo is offline
Rep: 10 Posts: 3
modeling hull of tanker ship in Rhinoceros
Hi,
I've inserted stations in Rhino (file is in atachment) and now I'm having problem with creating hull, so if someone with way more experience than I have could give me some tips on how to properly use loft option, I've tried but the result is horribe.
Old 07-27-2009, 03:08 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 156
Hi Jozo,
There are several techniques available for designing a hull like this in Rhino. You may want to start by looking at this McNeel wiki page: http://en.wiki.mcneel.com/default.as...l/HullMod.html.
What part odf Croatia do you live in? My Grandfather came from Hvar.
Old 07-28-2009, 04:23 AM
Rep: 10 Posts: 3
Tnx for the answer, I'll try to model a hull using T-splines, that Alfa Romeo in that tutorial looks awsome
I live on the island called Krk but I've visited Hvar and it's almost as nice as Krk
Old 07-30-2009, 11:53 PM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 316
your curves are not suitable for a single "Loft" command, so try "NetworkSrf" command , but for using it you have to take more curves i.e. waterlines, the deck like etc,
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 08-04-2009, 09:53 AM
Rep: 10 Posts: 3
could you please explain how to use that command properly? would it be enough to insert two waterlines, one in the middle and one on the top (deck line) or should I insert some more lines? Is one buttock enough?
Old 08-04-2009, 10:28 AM
pavel915's Avatar
Rep: 154 Posts: 316
look your bow curve is not continious, there are several curve segments in the bow,make it one single curve which devine the bow, then you look in the manual of rhino (press simpy f1 to open the manual) and go to surfaces>from curve network and read what are the conditions of "networksrf" command which is as follows:
*there should be curves curves in 2 directions,
*curves of same direction can not cross one anothers,
*curves of opposite direction should cross other direction curves so closely,
for the hull type of hull form you are trying to model you have to take the deck edge and several waterlines specially in the bottom , as the shape of stern at bottom is diffrent,
Md. Al-Amin Pavel
Albert Einstein
Old 10-27-2009, 08:48 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
i just tried to create a trimesh surface of the hull from ur given lines and this produced ( attached)
during the hydrostatic calculation maxsurf give all the values except displacement value ( it always show o )
what may be the reason? i am now trying to fit the marker with NURBSurface .. may b i can post if i can do that
Best Marine Design Software for Hull Modeling? (2008-09) Admin Software 123 01-20-2010 04:19 AM
Hull Modeling With Rhinoceros Antisthenes Software 14 08-08-2008 04:41 PM
Modeling the ship with 3D Studio Max xhanasico Software 3 07-03-2007 08:58 AM
Best Marine Design Software for Hull Modeling? (2006) Admin Software 95 01-01-2007 02:59 AM
Rhino/Solidworks hull modeling mattbyrne Software 1 01-11-2005 10:46 PM
