| modeling full keel hulls Just wondering what the general consensus is for modeling full keel or modified keel hulls. Is it best to model them separate and join them or ad several rows of points to a round hull? FWIW, here are the lines I'm trying to model (Alberg designed Pearson Triton): |
| It depends why you are modeling it and if it is to be built, what material is intended. Either producing the hull and keel separately and then fairing or producing the entire hull keel as one is valid but depends on your skill level with the software.
| Turnbuckle I find it depends on the designs profile. Some you can do with just two surfaces, hull and transom, sometimes three, hull, sternpost and transom. In this case I would use two surfaces joined at about the third diagonal for the hull and keel because of the overhang at the stern, and a transom surface. The rudder cut out makes that area a bit more problematic and I would most likely cut and trim that area after fairing the hull. |
| Its this question that made me find this site a few years ago trying to work out how todo it. Take a look at this thread Software advice for J Class inspired hulls designs Andrew Mason picture is very useful |
| Adjusting lead ballast in a full keel | dhornsey | Sailboats | 10 | 01-22-2009 05:04 AM |
| Raw intakes, exhaust and other thru hulls on Fiberglass Hulls | ChrisN67 | Boat Design | 7 | 12-27-2008 01:40 PM |
| Modeling | capaworks | Fiberglass and Composite Boat Building | 1 | 09-30-2006 07:59 AM |
| Affixing full keel to canoe body | RDB | Boat Design | 0 | 05-17-2004 06:58 PM |
| modeling full keel hulls in rhino | Kirk Hill | Software | 12 | 11-17-2003 07:58 PM |
