| i am trying to make these models myself but i am strugling... is thare any way to change default hull shape that delft ship creates when i choos number of points (longitudinal and verical) and dimensions?! it always looks lika a yacht or smth. similar and there is a lot of work to be done to transform it to a barge for example... |
| it's me again.... i'm still having trouble modeling this barge.... i wanted to ask you HJS how did you model it?! i counted 6 points in vertical direction at some places and 4 in other. did you start with 4 and added more points where it was necesary?! i started with 6 and it is a mess and then i started to look at your model more carefuly and saw the 4 points and 6 points at different places... |
| i would say i almost got it... i am attaching the file that i made and i would like to hear your oppinion. also i would appriciate if someone would explain to me why does the lowes waterline has that silly shape?! i thing i got intersections ok but that waterline is really silly (it's marked red in the bmp file also attached)... how did that happen if i did sections ok (well almost)?! ![]() |
| [quote=photoivek;445033]i would say i almost got it... why does the lowes waterline has that silly shape (well almost)?! QUOTE] well almost! that's it the flat parts are not flat in your design look carefully at my version you will see that some control lines are sharp, red and you have to put your control points exactly in the right position and check up the position of the intersections check my version again good luck js
__________________ www.sassdesign.net I'm not lost, I'm just uncertain of my position. I'm still confused, but on a higher level |
| THX i will try it again tomorow morning... i've read it and and then i guess i still have to read it once again... ![]() i have some trouble with english words for shipbuilding terms.... |
| i think i did it a bit better now... i would apriciate a critique... this is attempt #4... so is it better?! |
| Paintshops for the body of the boat | Daryush | Boatbuilding | 5 | 06-07-2009 07:17 PM |
| need body plan of a 6-8 m speedboat | Alfonso | Boat Design | 2 | 10-13-2008 06:40 AM |
| better body plan | CapKos | Boat Design | 4 | 05-07-2007 03:34 AM |
| how do you make your own fiberglass body | huntermike32 | Fiberglass and Composite Boat Building | 12 | 11-02-2005 05:43 PM |
| glassing over body filler? | LKJR | Fiberglass and Composite Boat Building | 4 | 05-27-2005 02:47 PM |
