| Modeling in 3D Studio Max? Hello newbie just arrived needing to get straight into yacht design using 3DS Max 5. Any advice would be really appreciated. Looking for a tutorial on Spline Mesh Modelling atm |
| 3D studio Max trying to make a yacht hull at the moment all I can do is edit solids converted into meshes I tryed subtracting a boolean plane from a shape, but all it did was cut the object without using a solid object as a cutting tool it isnt subtracted I tried attachting a sequence of splines the applying a cross section modifier and then a surface modifier but it didnt appear to work got any tips? |
| This isn't the answer you're looking for, and maybe someone more experienced with 3DStudio Max will step in and provide an answer, but I think you would find it far easier and faster to use dedicated hull design software or Rhino (see: Quick hull in Rhino) to get your basic fair hull shape - I love 3D Studio Max for importing models from other programs and rendering them, but find it difficult to impossible to do percision modeling of hull shapes in it. |
/Claes
__________________ Claes Lundstrom |
| Thank you very much for the links, think I saw the same thing at turbo squid, some guy making a Biking ship- but his tutorial wasnt 3DS Max, I think I will have a go at rhino- will investigate the 3dcafe, havent been there for a while. |
| loft method boat in max loft method boat in max ---------------------- weeeeel off the top of my head guv. Start by drawing your three elevations as splines. [Best if they are to the same scale] Loft one elevation and use the fit controller on the deformations dropdown [On the modifier tab of the loft object] Make sure the 'make symmetrical' button is unchecked. [The one with the padlock on] Use the 'get shape' to select one of your other elevations and rotate it round to the right position. Do the same with the other and your there. To make small adjustments tweak the points on the fit controller dialogue. Thats how I would have done it... before the accedent... Looking for work, Joeg Quote:
| another way alt draw Xsections and loft along a straight spline use the % along path to set the spacing between the xsections and the 'getshape' to select each one in turn. |
| Or Turn the spline Xsections in to nurbs and use the blend modifier on the 'surface creation' dropdown on the object modifier tab. Move the mouse over a spline segment and it will highlight blue, drag to another to create a surface. For this to be effective each Xsection should have the same number of vertices and they should be roughly aligned. The easiest way to achieve this is to create each by copying the previous one and editing the position of the vertices, start by drawing the most complex Xsection (probably in the middle somewhere)and working outward. |
| Or u can also join the nurbs curves together... and using U-loft to create the surface... try joining the vertices of the splines as close as u can with the least tension. Its still possible. then using U-loft is going to be much easier with a single cross section being a single spline. Good luck .. |
| Thanks for the tips I will give them a go, I found Aaya and Alias much easier for surface modelling and surfacing a mesh accross joined splines- I'm pretty sure 3dsMax doesn;t have the same funcionality... right? Although from the sounds of it your U-loft tips could be exactly what I need to play with, to avoid these dreadfull sausage shaped hulls and start getting some real hydrodynamic shape into them |
| 3D Studio Max | Alec | Software | 1 | 10-02-2004 06:34 PM |
| VRMesh 1.0 – a new style of sketch-based 3D modeling tool | nicedays | Software | 0 | 08-13-2004 03:07 AM |
| Yacht interior layout | Polarity | Software | 48 | 04-13-2002 09:12 PM |
