Old 09-24-2010, 10:14 AM
kkd kkd is offline
Modal analysis of a beam attached to spring mass system
Can "Modal analysis of a beam attached to spring mass system" be done by nastran, ansys , abaqus...
I know nastran can solve, but as mixed elements, will there be any error in result?
Old 09-24-2010, 11:09 AM
Rep: 1758 Posts: 1,561
There is always error in any model system because the model is limited by it's resolution and assumptions. The better question is "Is the computational art sufficiently advanced to conduct modal analysis of a beam attached to a spring mass system within the necessary engineering accuracy?" The answer to that is maybe, and has been for over half a century. It all depends on how fine you want to slice the apple, some things are acheivable, others are not within our ability to correctly model. See Theory of Seakeeping by Korvin-Kroukovsky, SNAME, 1961.
What exactly are you looking to solve? Maybe we could point you in the proper direction.
Old 09-24-2010, 11:24 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
I think this is the wrong forum for this kind of questions. You have more probabilities to find the answer on forums dedicated to FEM software - like the this one, for example:
http://www.eng-tips.com/threadminder.cfm?pid=727
Cheers
Old 09-26-2010, 06:19 AM
alidesigner alidesigner is offline
Rep: 93 Posts: 171
The short answer is yes. Any reputable fea program will give you correct theoretical results based on the inputs you give it. You can mix element types.
Steve Chapple
www.cncmarine.com.au
Consulting & Alloy Kit Boats
Old 09-26-2010, 08:02 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
As with any FEA, if you're unsure, find a text book. Find one that shows how to solve, manually, what it is your after, in basic simple form.
Then rerun the same model/analysis from the text book in your FE software and compare the reuslts. That should give you an indication of the %'age error in a known and fixed result.
Wet or dry mass in virtual mass of a towed object? floating Boat Design 7 06-16-2009 08:43 PM
Modal Analysis issac82 Software 1 03-26-2008 01:27 AM
Catamaran beam vs trimaran beam seadog1970 Multihulls 11 08-19-2007 05:49 AM
I need some ideas PLEASE HELP pics attached ! clctrader Powerboats 12 06-08-2006 01:35 AM
how much does a laminate spring back pvanv Boatbuilding 2 11-03-2003 06:47 AM
