Old 04-10-2011, 08:13 AM
mokchie mokchie is offline
Rep: 10 Posts: 5
Is Michlet suitable for RC boat?
Dear all,
I'm designing an RC fishing boat with about 10kg displacement,to estimate its resistance I have spent a lot of time studying Michlet.My initial design is a catamaran with transom stern and a low L/B ratio,then after reading some threads in this forum I'm aware of that transom stern and a low L/B ratio may lead to inaccurate evaluation. So I have changed my design with a high L/B and no transom stern,then at certain speed the outcome is about half of the initial's,and at another bigger speed it has the same value as the initial's.Is that reasonable?Or maybe Michlet is not suitable for a boat so small like mine.
This is my first thread,any suggestion is welcomed.
Old 04-10-2011, 11:38 AM
BYDE BYDE is offline
Rep: 66 Posts: 54
hello Mokchie,
Michlet is based on thin-ship theory (if I'm not wrong, I haven't used it), so the hull must be 'thin'. That means a high L/B ratio, doesn't matter the length.
You didn't state your L/B and I didn't fully understand what problems you encountered, especially I found some difficulties in figuring a catamaran with low L/B...
Old 04-10-2011, 09:34 PM
Rep: 10 Posts: 5
Originally Posted by BYDE View Post
hello Mokchie,
I'm sorry, BYDE,I didn't express accurately,by saying “a catamaran with low L/B” I meaned the hulls of the catamaran have a low L/B ratio as 4.6.And I have changed it to be 8.3,then I found the outcome is largely different from the one's before.
But now things have changed, I found I made a mistake when comparing the two boats:they have different displacement volume(one is around 10kg,the other is only around 7.0kg) so they can't be compared directly.And still I have found the offsets I exported from Freeship is wrong.May be after I correct the offsets and set the displacement volume of the two boats a same value their outcomes would not be so much different.
Do you mean a boat of that scale is still suitable to use Michlet? I'm glad to hear that.Because I can't found any other way to estimate the boat's resistance. Now I think I can use Michlet without being hesitating.
Much thanks BYDE.
Old 04-11-2011, 03:02 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
To estimate skin-friction, Michlet uses either the ITTC line or a variation of Grigson's line. These lines both assume turbulent flow from the bow which might not be applicable to small boats with Rn less than about 10^6.
Good luck!
Leo.
Old 04-11-2011, 04:46 AM
Rep: 10 Posts: 5
Good luck!
Leo.
Yes,the Reynold number of my boat is about 1.47x10^6, so it works in transition flow regime. But I think I can still use Michlet by modifying its outcome with Prandtl's formula:Cf=0.455/(lg(Rn))^2.58-1700/Rn. I have found the ITTC's answer is much bigger than Prandtl's formula's.
Thanks for your reminding.And your program is an excellent work, I benefit a lot from it,thank you so much!
Last edited by mokchie : 04-11-2011 at 10:17 AM. Reason: correct an numerical error
Old 04-11-2011, 05:12 AM
Rep: 66 Posts: 54
it seems like you give yourself a bit too much design freedom
Much thanks BYDE.
wait a second, just to be sure: it's a displacement hull, right?
Old 04-11-2011, 09:56 AM
Rep: 10 Posts: 5
Yes,it's a displacement hull.
You are right. I think I shouldn't set the ship's displacement volume less than 10kg, because the boat is designed to carry 1.5kg fish bait. If the displacement is too small the boat may trim badly when the bait is unloaded. I have to reconsider it carefully.
Old 04-11-2011, 10:19 AM
Rep: 66 Posts: 54
carry a bait, interesting... what are you going to do with the little boat?
you should fix a target weight estimating the weight of every component of the boat. It's an rc model so it should be an easy job.
if you don't have any special requirements, as i guess, i suggest you to pick a systematic series hull and scale it to your weight. quick, and you know the performance of the hull already
Old 04-11-2011, 11:15 AM
Rep: 10 Posts: 5
The boat is planned to carry a bait to sites far away from the shore, then unload the bait with remote controlling. I have tried to find some systematic series hull, but I doubt that after being scaled it's performance would largely change. And I like to do the design from scratch,it will make me more excited to do it.
I do agree a careful estimate of the weight shoud be made first,in case the displacement is not enough. And it will be very easy. Thanks for your reminding.
Old 04-11-2011, 11:55 AM
Rep: 66 Posts: 54
sounds cool
yes it will, in terms of wave resistance, as long as your hull fits in the ranges used during the systematic series experiments.
but of course, if you enjoy doing your own design then i understand.
good luck!
small shipyard looking for suitable boat for production swabbie Projects & Proposals 10 03-24-2012 05:50 PM
Suitable Jet Drive donaldknyu Jet Drives 7 04-20-2010 11:49 PM
Suitable Book for Small Power Boat Design info@mds.org.nz Powerboats 3 11-10-2009 06:02 PM
can't find suitable software just cruising OnBoard Electronics & Controls 7 05-16-2007 02:47 AM
How to choose a suitable engine orang laut Diesel Engines 24 02-11-2007 07:06 AM
