| Michlet and hard chines I am designing a long and narrow boat with a round bottom and a hard chine, on model tests I have noticed the wave pattern is significantly different from full round bilged hulls. I would like to do some resistance calculations on it using Michlet, does this make any sense or will Michlet totally ignore the chines in it's calculations? thanks, Arthur |
| The only part that matters with Michlet is what is below the surface. If you have complex geometry then you need to have more waterlines and more stations. Michlet will give a useful result. You should consider using Godzilla to produce an optimised hull to your constraints. You can force a hard chine if you want. If you give me some hull constraints I can give you an in.mlt file to use with Godzilla. Rick W. |
| Thanks for the answer. I can produce a good .mlt from Delftship, I think, or ar there some other things to concider? I am just worried abouth the influence of the chine in Michlet or any other software as it just looks to have a more impact than any other "basic" input. Regards, Arthur |
| Arthur Michlet handles chines. If you post the basic hull constraints I can see what Godzilla produces. The parameters needed are things like design speed, maximum length, minimum length, displacement, stability (metacentric height), beam constraints (if any), ease of construction (chines for example), turning abilty etc I normally start with the least constraints and see what an uncompromised shape looks like. Then I start adding other constraints to make it practical. Rick W. |
| Arthur If you already have the model and a Delftship drawing then the .mlt will be fine. I usually modify the speed range in the .mlt file. Michlet will also produce an image of the wave pattern so you can compare this with a photo of the waves produced by the model. Rick W. |
Regards, Leo. |
| question on placing reverse chines | northerncat | Powerboats | 12 | 05-05-2007 12:12 PM |
| "Hard Chines" | DaveK | Boat Design | 34 | 02-25-2006 01:17 PM |
| Freeship chines export to 2D and 3D | Drysideup | Software | 2 | 01-09-2006 10:04 AM |
| Chines, what influence do they have? | Danielsan | Boat Design | 4 | 09-12-2005 09:04 AM |
| Hard or soft chines & their effects on rolling | Parke Brinkley | Boat Design | 3 | 07-22-2004 05:05 PM |
