Old 03-04-2008, 11:02 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
Originally Posted by josemropero View Post
Hello Leo,
let me ask for a question for you. I think itīs easy but I donīt know how to do it.
In your in.mlt example Wigley file after completing the points that define the vessel you have to write the values of this tree magnitudes.
How do you calculate their values?
Thank you very much.
# Displacement Volume (cubic metres)
0.078658
# Length (metres)
3.048
# Draft (metres)
0.1905
The beam is calculated from the length, draft and displacement that you input.
For a Wigley hull the beam can be calculated using the block coefficient,
CB = V/(L*B*T) = 4/9
where V = volume, L = length, B=beam, T=draft.
Regards,
Leo.
Old 02-09-2012, 08:53 AM
TrustedShips TrustedShips is offline
Mr.
Rep: 10 Posts: 27
I downloaded Version 9.20, which does not seem to work on Win 7 (64 bit). Am I missing something?
Devu C.
A Freelancer (Goa, India)
http://trustedships.webs.com/
Old 02-09-2012, 02:19 PM
It works fine for me and many other Win7 64bit users.
What kind of error are you getting?
Old 02-10-2012, 08:29 AM
Mr.
Rep: 10 Posts: 27
All I see is this black window with boxes as visible in the attached image. I can't do anything to that window. Even the close and maximize buttons are disabled. I have to force close through ctrl+alt+del. Am I doing it wrong?
Also this message about color scheme appears.
Devu C.
Old 02-10-2012, 11:07 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Yeah, welcome to Michlet!
Now you can press "?" to get the list of commands and start playing with them. Or you can press "Esc" to quit the program if you don't like it.
But before you start (and then give up) I'd suggest you to read the PDF manuals in the folder "\Michlet 920\docs".
Cheers!
Old 02-10-2012, 11:19 AM
Mr.
Rep: 10 Posts: 27
Oh! Thanks a lot.
I thought that was an installation error or bad license.
Now I found the pdf files.... will give it a try....
Devu C.
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 04:00 PM
Option One - how big Willallison Option One 43 12-20-2005 05:44 AM
Michlet available again (but no longer free) Jeff Software 4 07-25-2005 01:20 PM
