Old 04-14-2011, 10:20 PM
phillipviana phillipviana is offline
Naval Architecture and ME
Rep: 10 Posts: 9
Michlet
I was using maxsurf to estimate the resistance of a container ship, but I was wanting to compare the results with michlet too. How can I download this program? Thanks
Old 04-14-2011, 10:31 PM
Rep: 10 Posts: 9
Michlet
I am trying to estimate the resistance of a container carrier that I designed on FreeShip in Michlet, but I am facing many difficulties.
Could someone help me with this,
at least how can i start...
thank you
Old 04-15-2011, 12:59 AM
Leo Lazauskas's Avatar
Leo Lazauskas Leo Lazauskas is offline
Rep: 1816 Posts: 1,422
thank you
See:
http://www.cyberiad.net/michlet.htm
For a start, read the manuals and run the examples.
Good luck!
Leo.
Old 04-19-2011, 01:15 PM
MJD12 MJD12 is offline
Leo,
I am trying to calculate the resistance of a monohull sailboat at different leeway angles. I read in the MICHLET users guide that the leeway parameter is reserved for future enhancements and should be left at 0.
I was wondering if there was anyway to incorporate leeway into the current version of MICHLET, or if you had any suggestions of alternative methods to accomplish this.
Any advice would be much appreciated,
Thanks
Old 04-20-2011, 12:11 PM
Originally Posted by MJD12 View Post
Leo,
Thanks
I made a start on this, but haven't got far. My lifting surface program can estimate the lift and induced drag of thin low aspect ratio wings, but they are very different from boat hulls! Still, if you have nothing else you could try modelling the leeway drag using the centreplane of the boat as a thin wing, and assuming the free surface is flat, i.e. a plane of symmetry. That's a "rough as guts" approach and I'd hope there is something better around.
Have you searched to see if there are any experimental results for sailboats? I seem to recall seeing a paper where somebody used the Delft series or similar.
BTW, I'm not convinced that Michlet is the best way to go for sailboats, unless their length-to-beam ratio is greater than about 7.
Good luck!
Leo.
Michlet fredschmidt Software 20 05-14-2010 09:47 PM
Michlet fredschmidt Software 59 04-13-2010 02:39 AM
Michlet pavel915 Software 73 01-17-2010 08:46 PM
Michlet Javaid Hosany Software 1 05-22-2008 07:12 AM
michlet mermont Software 13 07-20-2007 03:42 AM
