Old 05-11-2007, 12:07 AM
RThompson RThompson is offline
Rep: 106 Posts: 133
maxsurf - workshop Trimming
Hi there,
I am very new with maxsurf/workshop.
So I'v trimmed a surface in maxsurf and opened the design in workshop. when I develope a plate the trim is ignored.
The workshop training manual has a few words to say about it but i am none the wiser.
ie "... turn on trimming and intersection lines and check that the model has been trimmed correctly."
i assume "turn on trimming" means make trim 'invisible' through the display menu?
I'v ticked 'intersection lines' in 'contours'
how do i check the model has been trimmed correctly?
Any other suggestions to develope a trimmed surface?
thanks,
Rob
Old 05-15-2007, 09:08 PM
Rep: 106 Posts: 133
so heres the answer
the plate can be developed by defining its edges using various contour lines that must be turned on through 'display' (intersections, edges, sections etc), and thus the developed plate will be the re
Old 05-15-2007, 09:13 PM
Rep: 106 Posts: 133
so heres the answers
a plate can be developed by defining its edges using various contour lines that are turned on via the 'display' menu (intersections, edges, sections etc), and thus the developed plate is the shape required.
-pressing the shift button select the contour lines in order : aft fwd outboard inboard, and then goto the plate menu and select 'add a plate'.
Another way is to develope a surface with contour lines turned on then edit the shape of the surface in a drafting program using the contour lines.
Rob
Workshop Help chgege Software 1 04-26-2007 04:27 AM
Trimming in Rhino Willallison Software 9 02-05-2007 12:21 PM
trimming problem in rhino fede Software 4 06-12-2005 04:53 AM
surface trimming in Maxsurf, NavalDesigner and or Autoship innomare Software 5 02-14-2005 08:16 PM
Sail Trimming, Visuals brian eiland Sailboats 0 12-31-2004 11:47 AM
