Old 03-07-2011, 03:52 PM
Velsia Velsia is offline
floater
Rep: 15 Posts: 50
Maxsurf v11 - Can you span a Cat?
Hi everyone. I am trying to use the Maxsurf v11 package to produce a 17m Catamaran and have come up against problems when producing the polars in Span.
It tells me that the results aren't converging. I understand convergence but have no idea where the difference is lying.
I have used Span before but only with monohulls and haven't yet had this problem.
The manual mentions nothing about not being able to predict catamaran behavior. Has anyone experienced similar? Will Span model a catamaran?
I need help.
Old 03-16-2011, 09:31 AM
jen2 jen2 is offline
Rep: 35 Posts: 4
Nope
Hi Velsia,
the answer is no I'm afraid! Came up with the same problem just over a week ago.
Back to the hand calcs my friend!
Old 03-19-2011, 12:45 PM
Jenny Giles Jenny Giles is offline
Perpetual Student
Rep: 177 Posts: 53
Maxsurf has some very good features and some things like this that drive you crazy.
Semi-retired
Old 03-21-2011, 06:59 AM
floater
Rep: 15 Posts: 50
Thanks for the advice, back to the textbooks.
Old 03-25-2011, 04:36 AM
formsys formsys is offline
formsys
Rep: 37 Posts: 73
The VPP algorithm in Span is based on the published IMS approach. That approach does not cover sailing catamarans.
Old 03-27-2011, 11:56 PM
Laranjo123's Avatar
Laranjo123 Laranjo123 is offline
Naval Architect/Engr. FG
Rep: 17 Posts: 128
I have maxsurf v13 ^__^
Old 04-13-2011, 01:47 PM
Speng Speng is offline
Rep: 10 Posts: 20
Doesn't matter whether you have V13 or not Span is an IMS clone. As good as that may be it doesn't do multis. The only commercial VPP I know of that does multis is WinDesign from the Wolfson Unit.
I must say though that if you're doing powering predictions for multis and need resistance that maxsurf's resistance program ( I forget the name) is good for that.
Old 04-13-2011, 11:03 PM
formsys
Rep: 37 Posts: 73
Yes, Hullspeed is the module you are thinking of and the slender body method in it is well suited to catamaran resistance prediction. Info and pretty pictures at
http://www.formsys.com/maxsurf/msproducts/hullspeed
Old 04-15-2011, 07:50 PM
Rep: 10 Posts: 20
Ya. I really liked it for that. You can go from maxsurf file to resistance curve in 5 minutes. One thing I wasn't sure of is if you could add things like wind resistance etc like you can in the Wolfson powering program. I didn't spend that much time looking at it I just spat out the hydrodynamic drag curve and took it to a spreadsheet where I added the other bits or resistance/drag that I wanted.
Old 04-16-2011, 01:38 AM
formsys
Rep: 37 Posts: 73
Yes, with the regression methods in Hullspeed (not the slender body methods) you can manually modify the settings for things like frontal wind area, transom area, appendage area etc.
Can you span a Cat? Velsia Multihulls 3 03-07-2011 04:56 PM
span results Scofield Sailboats 1 04-21-2010 07:20 PM
Help on Maxsurf Span quicova Software 0 12-28-2008 10:53 AM
unsupported span Hisham Class Societies 7 05-18-2008 05:43 AM
