| Maxsurf Surface Help I hope someone out there can help me. If you import a surface into Maxsurf can you manipulate it? I have a iges surface that I want to fair in Maxsurf. I cannot figure out how to get the control points to show up so that I can fair the surface. If anybody has some input that can help me out I would appreciate it. Thanks |
| Can you see the surface that reads in? Does it render OK in the perspective view? If so it has come in as a NURBS surface and you will be able to modify it. Check that the surface is not locked (Surfaces menu->Surface Properties dialog). Also, it will probably come in as being assymetrical, you may also wish to turn on the symmetry option in the surface properties dialog. Unfortunately a lot of surfaces coming from general purpose CAD programs are created by fitting to sectional data and have huge numbers of control points, making them hard to modify. If this is the case you may wish to generate a large number of markers and then fit a simpler surface to the marker data.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| iges trimmed surface problem in maxsurf | hasicktear | Software | 16 | 02-13-2006 12:25 PM |
| surface trimming in Maxsurf, NavalDesigner and or Autoship | innomare | Software | 5 | 02-14-2005 08:16 PM |
| how to transfer the shipconstructor surface to maxsurf | ageny | Software | 5 | 10-27-2004 10:39 AM |
