Old 03-11-2006, 05:53 AM
squivo squivo is offline
Rep: 10 Posts: 7
Maxsurf Question
I have an unusual question for you. Sometime ago I did an Maxsurf model, If I'm not wrong It was imported from IGES surface. But for some reason I cant't remember now, the aft and stern of the ship are in the opposite direction, i.e the forward side is in the left of the maxsurf screen while the aft side is on the right.
How can I put it in the right direction? Is that even possible, do you have any other suggestion?
Thanks in advance
Old 03-13-2006, 09:17 AM
Rep: 206 Posts: 391
There are two ways of doing this. You can either set the orientation of the model when you import the file, this alows you to specify which direction is up, forward, starboard etc., as well as the sign + or -.
If you have already imported the file, you can use the Flip command to flip the surface around a specific axis.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Maxsurf Help TimClark Software 5 12-28-2005 11:03 AM
Maxsurf Question? cmcguinness Software 3 02-07-2005 04:15 PM
Maxsurf Q (AutoCad -to-Maxsurf) cmcguinness Software 1 12-01-2004 04:00 PM
MaxSurf profile question ErikG Software 1 10-13-2003 12:06 AM
Maxsurf Curvature question ErikG Software 4 03-18-2003 02:30 AM
