Old 05-12-2005, 11:51 PM
alimahmoud alimahmoud is offline
Rep: 10 Posts: 13
Maxsurf & Prosurf Limiations
Hi every one.
I'm new member in this forum.
Iwould like to ask those who have experince in using Maxsurf and Prosurf, what are the limitations of these software.
Thanx.
Mahmoud
Old 06-16-2005, 12:49 AM
Rep: 10 Posts: 13
Hello & Hi every one.
Does anybody have Prosurf's user manual?
Mahmoud
Old 06-16-2005, 11:17 AM
CGN CGN is offline
Rep: 121 Posts: 547
I don't think they have the manual online, but it has a very good tutorial (prosurf)
I like both softwares i don't see a huge diference between them
(on what i can achieved), prosurf has more import export capabilities than maxsurf, and is lower price than maxsurf for the full verison.
One of the main diference i can see is the way prosurf handles a surface, and if you are going to use maxsurf products like hydromax for example better stick with maxsurf.
besides that i think the two are very good softwares
Old 06-16-2005, 09:04 PM
Mikey Mikey is offline
Rep: 75 Posts: 368
I have problems finding what is 'real' limitations for me in MaxSurf, most things can be tweaked.
Import Export is a bit limited in MaxSurf but it is not a door stopper in any way, you just need a software in between to do the translation sometimes, and if precision is set to highest, no problem.
Porcupines don't work if you have stiffness to 2 in MaxSurf.
There is no button for showing diagonals, that's really irritating since it is what I use the most.
As CGN said, if you are planning to go on with hydrostatics in the next step, then MaxSurf and HydroMax are good choices. Don't underestimate MaxSurf, it is a good programme.
Good and quick support (here at this forum) from Andrew at MaxSurf is valuable too.
Mikey
Old 06-17-2005, 02:12 AM
Rep: 206 Posts: 391
Mikey
When stiffness is set to two, the curve becomes linear. A straight line has no curvature, therefore zero length to the porcupine.
Andrew
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 06-17-2005, 02:54 AM
Rep: 10 Posts: 13
Hi CGN,
thanks alot for you valuable information.
I will try to surf Prosurf tutorial.
Mahmoud
Old 06-17-2005, 02:58 AM
Rep: 10 Posts: 13
Hi Mikey
thank you very much for replying
hope to hear from you
Mahmoud
Old 06-17-2005, 03:03 AM
Rep: 10 Posts: 13
Hi Andrew
waiting to hear from you.
I'm really intresting to know more about Maxsurf software for ship hull design, I do appreciate you help if providing me with articles or URL from which I can get enough information about Maxsurf as well as Prosurf if possible
thanx
Mahmoud
Old 06-17-2005, 02:23 PM
Rep: 206 Posts: 391
Mahmoud
I notice you are from UTM, have you logged on to the Maxsurf Academic website and downloaded the manuals, tutorials and technical papers? This should provide you with a reasonable amount of reading material.
Any other questions, please ask.
regards
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 06-19-2005, 10:13 PM
Rep: 75 Posts: 368
Yes, true, no argument there. But it would still have been good to see the shape that the control points make.
Mikey
Old 06-19-2005, 10:21 PM
Rep: 75 Posts: 368
Mahmoud, this thread gives some good advice.
http://www.boatdesign.net/forums/sho...1438#post51438
Mikey
Old 09-17-2005, 01:24 AM
Rep: 10 Posts: 13
Iges Foramt For Nurbs Surface
Originally Posted by Andrew Mason
Mikey
Andrew
Dear Andrew and all forum members,
could you please help me to conevrt a NURBS surface into IGES format to link with any CAD/CAM system. I use to generate the NURBS surface using my on program (C++ with OPENGL).
THANKS, and waiting for you reply asap.
Mahmoud
Old 09-17-2005, 06:43 AM
Rep: 206 Posts: 391
I notice you are at UTM so I assume you are eligible to download a copy of Maxsurf Academic. If so, download and run the program and then create a surface with the right number of control points and correct degree in U and W directions. Then copy and paste your control points from your program or an Excel spreadsheet. Export via the IGES export function and Voila!
Andrew Mason
Formsys
Maxsurf Academic
Old 09-18-2005, 10:39 PM
Rep: 10 Posts: 13
Hi, dear Andrew
thank you very much for valuable information. I will do what you advice to do, any problem I will post it forward to you.
see you
Thanks alot.
Old 09-19-2005, 11:36 PM
Rep: 10 Posts: 13
Need Help (How to create new surface (using Maxsurf))
Hi,
Dear Andrew,
I did download Maxsurf Academic version, but I found difficulties to create new surface with the desired number of rows and columns along with the degree. I tried the following:
1- File - New Design
2- Surfaces - Add Surfaces (Default).
to change the properties of the surface created to the desired surface it is problem for me.
I tried to open any of the existing surface, it is ok but the problem it is not easy or no grantee to find surface with same properties (equal number of control points and same degrees).
So please can you help me to solve the problem.
thanks alot
Mahmoud
Q. Lines-planes form AutoCAD to Maxsurf ? cmcguinness Software 0 12-06-2004 05:02 PM
Prosurf Eric Sponberg Software 2 04-12-2003 09:05 AM
New ProSurf 3 Software Software 0 06-29-2001 08:34 PM
