| You need to add columns and rows manually. Columns can be added in the profile or plan window, rows can be added in the Body Plan window. Simply bring the window to the front and select Controls->Add Column (or Add Row). Click on the design and a column (or row) will be added. When you have the correct number of rows and columns, go to the control points window and copy and paste your control points. To change the degree (i.e. stiffness) of your surface select the Surface->Properties dialog for your surface. Hope this helps Andrew
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| Thank you Mr. Andrew Hi, Dear Andrew thank you very much, Iam very greatful to your great help, wish you all the best. Mahmoud UTM |
| Surface Thickness Hi, Dear Andrew hope you fine. first, thank you very much for you help. the surfaces are generated correctly. for some purposes you may need to change the SURFACE THICKNESS, I want to make the THICKNESS about 3 mm. I noticed that the surface thickness is a portion (%) of the material that can be used. (maximum you can get thickness eqaul to 0.01). So please can you help me to make the THICKNESS about 3 mm using Maxsurf. thanks alot Mahmoud |
| More on THICKNESS Hi Dear Andrew, Actually, I followed the steps mentioned in the Maxsurf user manual, but I haven't seen the effect of changing the thickness as descriped in the manual. thanks Mahmoud |
| Mahmoud You can specify thickness inside or outside in whatever your current units are (mm, metres, inches etc.). You need to specify the direction of the surface normals using the Outside Arrows display, and then you need to turn on Deducted Sections in the Contours dialog to actually see the effect of the deductions.
| Surface Thickness Hi, dear Andrew, I did exactly what you mentioned, but still I can't see the effect of changing the surface thickness. brought on the Perspective Window. Display--Arrow Outside(ON). Display-Contours - Deducted Sections (ON). as explain in Maxsurf User Manual. may I made some mistake but actually, the above are the steps that I have done. Thanks alot Mahmoud |
| Turn Contours->sections on as well, let me know if that helps
| No Change Dear Andrew, no change in the surface thickness even turn the cotours -> Sections (ON) beside Edges and Deducted Sections. thanks alot Mahmoud |
| Q. Lines-planes form AutoCAD to Maxsurf ? | cmcguinness | Software | 0 | 12-06-2004 04:02 PM |
| Prosurf | Eric Sponberg | Software | 2 | 04-12-2003 08:05 AM |
| New ProSurf 3 Software | Software | 0 | 06-29-2001 07:34 PM | |
