Old 03-07-2005, 09:45 AM
japix japix is offline
Rep: 10 Posts: 3
Maxsurf problem !
Hello everyone
I have a little bit broblem with maxsurf .If I saving design and try open it again a get the message "maxsurf cannot open this entire design.Please select up to 3 surfaces " This is a problem because I have 9 surfaces !
This maxsurf is a tutorial version.
I`m very thankful for all kind of ansvers
Japix
Old 03-07-2005, 11:39 AM
Danielsan's Avatar
Danielsan Danielsan is offline
Amateur designer-builder?
Rep: 10 Posts: 229
As I was told, and I think you can find it on the forum, the demo (tutorial) version is limited to 3 surfaces.
That could be a good reason?
Daniel Peeters
Old 03-07-2005, 01:58 PM
Rep: 10 Posts: 3
Thanks Daniel
That i was thinking too....i`m asking just to be sure.
-Japix-
Old 03-08-2005, 03:38 AM
Rep: 206 Posts: 391
Japix
The demo version of Maxsurf is not limited in the number of surfaces you can read, but does not save or print.
Maxsurf Academic is a fully working version i.e. it prints and saves, however it is limited to 3 surfaces only. I assume that this is the version you are using.
regards
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 01-18-2009, 10:31 AM
mvd535 mvd535 is offline
Rep: 10 Posts: 18
The following question is refering to Hullspeed (HS).
Can I use HS to get hull resistence for a catamaran ?.
I was lookin at the HS Manual, but I could not find anything about it or how
use it for catamarans.
Many thanks to anybody can help me on this.
Old 01-19-2009, 05:12 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
yes .you can
If the vessel type is correctly defined in Maxsurf, Hullspeed will automatically generate a symmetrical mesh that is centred on the local demihull centreline.
Old 01-19-2009, 06:34 AM
Rep: 10 Posts: 18
Dear Zeroname,
Many thanks for your quick replay.
Yes, your are right, actually I do have my cata defined at MS, and I can read it at HS without any problem.
Question is about HS results after apply the right method, for example Holtrop. You see, the results are not considered right to me, so that is why I was doing this question through BDF.
Have you any experience by running catamarans at HS to predict speeds ?.
If is so, can I send my MS file to you, so you can feed me back with what you will consider correct in term of hull resistence results ?.
Thanks
Old 01-19-2009, 10:33 PM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 252
mvd,
i am not much expert on catamaran , it will be better if you ask Andrew Mason to help u if he want.
thanks
Old 01-20-2009, 07:54 PM
Rep: 206 Posts: 391
The only method in Hullspeed that is suitable for multihulls is the slender body method. Holtrop will give you the resistance for a single hull, but multihull resistance is much more complex than that due to the interactions between the hulls.
Have a look at the details of the slender body method in the Hullspeed documentation at http://www.fdsfiles.com/releases/manuals/HSManual.pdf.
Page 22 describes the method for monohulls, Page 26 starts the description of multihulls.
Andrew Mason
Formsys
Maxsurf Academic
Old 01-21-2009, 08:05 AM
Rep: 10 Posts: 18
Andrew,
Many thanks for your appreciated answer.
Unfortunately I do not have direct access to Maxsurf and Hullspeed software but through a MS & HS licenced naval architect friend that is giving me consultant services with charge.
Additionally, no one here, that I know, has updated to release 13, which is, as far as I understand, the only version that has catamaran analysis.
So, question is : Are you able to give me this type of service ?.
I already paid for the MS file which I can send it to you.
I can pay to you by sending your fees amount through FedEx or similar.
Also, it will be very interesting to know any current special offer from Formsys (if available), so I can study the possibility to buy the MS & HS last version software licence (one seat) for me.
According to the Formsys website, there is no MS representative here, so this
let me free to buy from any country including Australia.
Old 01-22-2009, 12:36 AM
Rep: 206 Posts: 391
As much as I appreciate the offer of getting paid, I just don't have sufficient time to take on consulting work. However there may be Hullspeed users on this forum who can help you.
Please contact Carolyn Hawley at (email: carolynh at formsys.com) to discuss pricing options, I'm sure she can work out something that is suitable.
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 01-23-2009, 08:18 AM
ekamarine ekamarine is offline
Rep: 36 Posts: 43
mvd,
You can contact through Formsys website to get an offer and also a trial copy. It doesn't matter whether there is a representative in your area or not.
iges trimmed surface problem in maxsurf hasicktear Software 16 02-13-2006 12:25 PM
Maxsurf network Problem Joe Lu Software 1 04-27-2005 12:49 AM
Maxsurf problem - deck affects displacement PaulCoffin Software 2 04-29-2004 06:57 PM
a problem with maxsurf? zhmeww Software 0 04-22-2004 04:44 AM
