Old 12-01-2011, 11:01 AM
CmbtntDzgnr CmbtntDzgnr is offline
Rep: 101 Posts: 110
Originally Posted by fcfc View Post
Maxsurf, solidworks, rhino, IGES file format, and other do handle internally mathematical object NURBS surfaces.
Freeship uses internally mathematical object subdivision surface. When you import an IGES surface, it does recompute the subdivision surface closest to your IGES surface. That why you get a catastrophically great number of control points.
Hehehe.... "catastrophically great number of control points"... I was thinking "debilitating", hehehee...
I exported FROM Free!Ship my model as dxf. Imported into PolyCAD. Saved as PolyCAD. Re-imported into Free!Ship. Ended up with around 1,549 leak points. Tha's not just the above-waterline control points, but the hull as well. But, it depends on the exact changes one makes to the surfaces or curves, too, I think, to get it to some manageable number.
I love the CAD-like approach to hull design in PolyCAD, but thoroughly enjoy the various reports of Hydronship. In Free!Ship, my eye-hand use of the control curves/porcupines is not fine enough, and my exported dxf surfaces have undulations that sometimes won't thicken properly to 16mm, but will to 1mm or 6mm. In PolyCAD, I can manually enhance my curves to be much easier on the ACIS kernel in Punch! ViaCAD (although it would be nicer if ACIS could figure out how to pre-fair lines and ask the user to allow it for the sake of making a surface thickenable to the amount the user needs/wants), and that makes PolyCAD a new star for my took chest.
Old 12-02-2011, 04:15 AM
hans hans is offline
BOC
Rep: 10 Posts: 5
Hi GavinM.
I might be able to help. Send me a private mail
line to inside planking in delftship/freeship or maxsurf darlian Software 5 02-25-2010 07:25 PM
Freeship KN? hersegovia Software 8 10-17-2009 09:41 AM
Help Please (need freeship, maxsurf, rhino file of stern trawler) mkovac67 Boat Design 0 04-19-2007 04:42 PM
maxsurf to freeship!!! pavel915 Software 22 12-08-2006 10:10 AM
Maxsurf Q (AutoCad -to-Maxsurf) cmcguinness Software 1 12-01-2004 04:00 PM
