Old 09-05-2010, 06:05 PM
KRL KRL is offline
Rep: 10 Posts: 19
Maxsurf
Hey guys i am new to this forum so hiii!
I have a lines plan on Autocad and i need to calculate the volume of the hull in order to find the gross tonnage.
I have created a 3d dxf from the 2d lines plan in autocad by simply moving each section in the z direction to obtain a half hull 3d. I then saved it as a DXF and imported the dxf file into maxsurf.
I must say i am a beginner to Maxsurf. The importation works fine and i managed to generate a grid from markers, group markers by station, delete duplicate markers, sort marker stations and re-order selected markers.
My problem is that when i import the dxf the markers are out the grid box and away from the reference point location (yellow cross in a circle). When I then generate the trimesh I get two half mirrored about the reference point location instead of a complete hull. I tried importing a complete hull rather than a half but it still did not work.
I have no idea why this is happening and it is driving me insane! Could it be that I am not saving it properly in ACAD or something to do with the coordinates in ACAD??
Can anyone help please???
Old 09-06-2010, 02:04 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 262
you can calculate the volume in manual way too. generate offset table from you lines plan, then use appropriate simpson's rule to get the area and volume.
Regarding Maxsurf, i think in ur autocad 3d lines, the origin is not set up correctly. check it in autocad, set the origin at the midship or at the aft pp.
origin means X,Y,Z co-ordinate points should be 0,0,0
UCS - just type in UCS to the command line - the select o
(object) and moved the UCS to where it should go. -
you can take the help from manual "Learning Maxsurf.pdf" chapter 11 (Chapter 11 : Creating a Maxsurf Model from Existing Data)
on this topic.If u dont have , u can download it from their website.
DAre To DreAm
Old 09-06-2010, 03:47 AM
KRL KRL is offline
Rep: 10 Posts: 19
I have already worked it manually but it is a rather lenghty process so I decided to learn maxsurf as it would save time plus would confirm my hand caculation.
I also did try follow chpt suggested and put the orgine at aft perpendicular this is why I cannot understand why it is not working properly.
Have you ever done this process before that is calculate hydrostatic with maxsurf from a lines plan in acad?
Old 09-06-2010, 04:10 AM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 262
yap/// i did it to generate Tri-mesh surface to calculate hydrostatics.
if u cant do it,, u can mail to support@formsys.com and attach the 3D lines plane too.. writing ur problem..hope u will get a reply soon.
DAre To DreAm
Old 09-28-2010, 08:07 AM
udyacht udyacht is offline
Rep: -33 Posts: 9
have you resolved the problem , if not ,may be i can help you !
UID Yacht Design,www.uidyacht.com...
Old 09-29-2010, 01:17 AM
b1ck0's Avatar
b1ck0 b1ck0 is offline
Rep: 28 Posts: 86
After you imported 3d DXF did you set up your "Frame of reference" and "Grid Spacing" correctly ? I wonder if you can send me the DXF, because I want to gain some "fairing" experice.
Maxsurf please HELP!! lazeyjack Software 14 01-25-2012 12:32 AM
Maxsurf Help dfarris Boat Design 0 01-27-2009 01:03 PM
help with maxsurf rob_fox Software 4 05-19-2008 09:55 PM
help with maxsurf snow 57 Software 7 01-10-2007 10:20 PM
Maxsurf Q (AutoCad -to-Maxsurf) cmcguinness Software 1 12-01-2004 04:00 PM
