| Lost or curve network in Rhino Dear friends, I have attached two pictures of a current yacht I am trying to model in rhino. It is a classic yacht 12 m length overall. I began modelling the bow section on its own and I will slowly move aft and decide how many surfaces I may need to model the yacht. One of the pictures I have attached shows one of the problems I am currently having to fit the surface to the sections, keel and camber. I have tried lofting the surface and curve network but I still get this inaccuracy in the fitting process, do you recommend any other method, also I am trying to keep things simple using 4 and 5 control points per station since ideally I will want to model the full surface of the hull as one, just as you can do in Maxsurf and here comes my other question, once I have modeled the surface in rhino will be easier to export the hull to maxsurf and work from there to model the hull and get hydrostatics and other related data or shall i continue from rhino with rhinomarine*. I look fwd for your comments Ivan |
| Try this, select Tools – Options – Mesh – Smooth & slower. I think all you have is a display issue. Gary
__________________ "The hand feeds the mind." Weston Farmer |
| This has nothing to do with your NURBS geometry. I bet it is just fine. Rhino simplifies the rendermesh to speed up rendering. Have a look at your File => Properties => mesh settings and apply the following settings (attached image). It will probably look a lot better then. |
| Lost | Texas Boater | Wooden Boat Building and Restoration | 3 | 06-20-2006 08:57 AM |
| Fitting a Curve to Offsets Points in Rhino | CET | Software | 6 | 01-04-2006 08:31 AM |
| Maxsurf network Problem | Joe Lu | Software | 1 | 04-26-2005 11:49 PM |
| GZ curve | ivansalasj | Sailboats | 7 | 02-23-2005 12:51 PM |
| curve of areas | ibi | Sailboats | 4 | 03-08-2002 08:51 AM |
