looking for tribon tutorials
Discussion in 'Software' started by rohinit, Sep 2, 2009.
  1. cugior
    cugior New Member
    Tribon surfaces
    Hi. I have imported a .sap surface file in surface/compartment and i have generate the dm file but i can use it in Basic Design. Must I have a closed surface? Must i create an envelope?
    Can someone help me? thanks in advance
  2. vinafk
    Likes: 0, Points: 0, Legacy Rep: 6
    vinafk Junior Member
    how you generate *.dml file?
  3. cugior
    cugior New Member
    I haven't generate dml file. Is it necessary?
  4. KMgreece
    KMgreece New Member
    tutorial for surface?
    Hello! My name is Kostas and I am a naval architecture student from Greece. Is there a place with tutorials on how to properly insert surface from rhino (rhino marine) to tribon. I tried the acis sat file way but although the surface is imported I can't get it working on calc & hydro :(
  5. zeroname
    Likes: 5, Points: 0, Legacy Rep: 90
    zeroname Naval Architect
    generate new lines in surface modules, open it in lines module, then make new surface and save it as DML file. after that u can work with any module with the *.dml file.
  6. KMgreece
    KMgreece New Member
    Hello! Sorry if I ask very simple questions but I am totaly new to tribon usage and still getting around. can you tell me how can I do this or even better where can I find a tutorial so I wouldn't have to ask and bother you with basic stuff.. All day I've been trying to export .bri files from rhino surface via fastship program e.t.c but can't get it to work.
    MY BASIC PROBLEM IS THIS : I created a surface in rhino (and rhino marine) and with cage edit I managed to get the exact LCB and Δ that I wanted. Then I insert this surface into tribon (sat acis file) but can't set any compartments!!!
    I don't know how to get lines out of the surface and all day I ve been trying to extract sections (and stem profile) but since I HAVE THE SURFACE (and in tribon it even shows it in meshes so it does 'understand' it), there must be a better and above all most accurate way to get again the surface I allready have :( any help will be greatly valued! thank!
  7. chandru447
    chandru447 Previous Member
    tribon
    hope i can help you with tribon set up if you are interested...
  8. bharatverma2511
    bharatverma2511 Graduate Naval Architect
    Hello Chandru,
    Thanks for the reply. I would appreciate if you can help me in learning the basic design modules of Tribon. It will be grt if u have some sample project to start with.
    Thanks;
    Bharat
  9. pdmsvn
    Likes: 8, Points: 8, Legacy Rep: 10
    pdmsvn Junior Member
    Hello everybody,
    We have document training about module LINE in Tribon and will train for who is interesting with it. You can buy training tutorial video from us and practice. Please contact me via email: pdmsvtvn@gmail.com
  10. adajko
    adajko New Member
    Tribon Export Xml File For Calc & Hydro
    Hi folks,
    I really need your help.
    I have completed my 3d model at surface& compartment and i want to import the xml file at calc & hydro in order to make all necessary calculations regarding the loading conditions etc..., but it is not available to export the file from Surface& compartemnt. as geometry file as there is no option for xml file.
    Can someone please guide in order to import the geometry file at calc& hydro in order to start my calculations.
    It would really help a tutorial if there is any.
    Many thanks in advance!!
  11. Beeran
    Likes: 0, Points: 1
    Beeran New Member
    Here is the complete simple tutorial for Tribon M3
