Old 10-08-2008, 07:53 AM
ROO ROO is offline
Rep: 10 Posts: 31
Looking for Nesting Program
Hi all,
I'm looking to purchase a stand-alone Nesting Program, DXF input file format, output G- Code and ESSI.
It's mainly for small yacht projects, producing plywood plates (router) some with beveled edges for deck and interior furniture ( I don't want to spend and arm and a leg), has anyone any suggestions ?
Old 10-08-2008, 01:26 PM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,578
I’m also looking for the same thing. I have CAM software that has no nesting function. Nesting manually is very time consuming. ArtCAM Insignia is one of the better ones but at about $5K US, it’s out of my reach.
http://www.artcaminsignia.com/downlo...x_download.htm
Gary
"The hand feeds the mind."
Weston Farmer
Old 10-08-2008, 01:35 PM
Design_1 Design_1 is offline
Water Logged Hack
Rep: 10 Posts: 71
ROO-
(1) What type of software are your drawing in?
(2) What type of router are you using?
I draw in Rhino, so I use Rhino Nest. Great software. Relatively inexpensive. Transfers well to most router and plasma cutter softwares. But it works inside of Rhino.
Regards
That is my take on it. That and 35 cents will get ya a cheap cup of coffee!
Old 10-08-2008, 04:16 PM
tandu's Avatar
tandu tandu is offline
Rep: 10 Posts: 21
I use cambam (http://www.cambam.co.uk/). I think there is a free version and the commercial version.
I'm planning to test cut3D, that seams interesting.
Giuseppe
http://www.dreamadvisor.eu
Old 10-08-2008, 04:20 PM
ROO ROO is offline
Rep: 10 Posts: 31
Thanks for you replies fellers, I use Delftship Pro, which I'm happy with, I bought Rhino for the flamingo and nesting extensions but couldn't wrap my head around Rhino which was a pity because its reasonable priced.
Yep $5000 for ArtCam is out of my reach to Gary, have you guys heard of
SigmaNest Lite, anyone got an idea of its price ?
Old 10-08-2008, 04:21 PM
Senior Dreamer
Design_1,
I use Rhino 4 for most of my drawing; I’ll have a look at Rhino Nest.
Thank you.
Weston Farmer
Old 10-08-2008, 05:01 PM
ROO ROO is offline
Rep: 10 Posts: 31
Cut3d and Cut2d
I just looked up Cut3d and Cut2d (Cut2D, $149 usd) it looks very interesting if anyone else would like to check it out and let us know what you think of it, I dont know if it will do bevel edges, cant see why not, if any one is interested go to www.vectric.com
Old 10-08-2008, 05:14 PM
ROO ROO is offline
Rep: 10 Posts: 31
duluthboats
Check out the student version of Rhino Nest there are no restrictions with any of the student versions, it cost a couple of hundred from memory.
Old 10-08-2008, 05:32 PM
Water Logged Hack
Rep: 10 Posts: 71
Duluth-
I draw in Rhino 4 as well. We used Rhino Nest when I worked in Tugs and OSVs. It worked well for us. It does get confused when you have a few parts closed to the sheet size you are nesting on though. Other than that, I would recommend it to anyone.
Old 10-14-2008, 01:58 PM
farjoe farjoe is offline
Rep: 26 Posts: 112
I have downloaded cambam but could not see how to nest patterns. can you give us a lead?
Old 10-15-2008, 05:58 AM
tandu's Avatar
Rep: 10 Posts: 21
Hello farjoe,
I was incorrect. Maybe, CamBam don’t have the nest functionality. I use it for simple shape that I organize by hand. However there is a forum related to that software, you can ask there for more information.
Giuseppe
Old 01-13-2009, 07:48 PM
ROO ROO is offline
Rep: 10 Posts: 31
Hi again just an update Cut2D and Cut3D arn't nesting programs, so cross them off.
Old 01-13-2009, 11:29 PM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
you can also look for autonest . its a kind a plugin of autocad . http://www.radansys.com.sg/autonest.htm
may be u can ask for 15 day trial version.
Old 01-14-2009, 01:21 AM
ROO ROO is offline
Rep: 10 Posts: 31
Thanks Zeroname,
I was looking at it today but didn't know if you needed AutoCad to run it. I'm evalutaing RhinoNest at the moment then after that I have Optimik then Plus 2D. But most don't do panelling, that is spreading a large part out over several sheets of plywood. I'll have a look at it can't do any harm.
Thanks again
which nesting dinghy berwick Boat Design 0 10-05-2008 05:45 PM
Nesting Dinghy Kilwinning Boat Design 6 06-21-2007 02:59 AM
Lisp for nesting but... internetturk Software 0 03-30-2007 09:02 AM
Nesting Software? internetturk Software 3 09-30-2006 05:48 AM
Nesting Dinghies bluewateringrid Sailboats 5 09-05-2006 08:55 AM
