Old 12-16-2008, 09:48 AM
sgcc113 sgcc113 is offline
Rep: 10 Posts: 2
looking for design software
Hi, Everyone. I posted before but put it in the wrong forum. Maybe some one here can help me out. I've been designing boats as a hobby for years, I've always used my trusty drafting table. I'd like to start designing, using a design program. I've browsed rhino, and pro surf, ext. My question is, Is there a program that will suite me. I'm used to Drafting everything out with " pen & ink" I'm not familiar with the high tech computer programs. Is the any software out there that makes this transition easier. What i would like is a program that allows me to draft by sight ,"something that I don't have to enter all my parameters". Then be able to take my design tweak it/ run hull speeds /Hydrostatic calc exc? Maybe all these programs let me do this and I don't no how to use them. Your advice would be great. Thank You
Old 12-16-2008, 02:24 PM
CGN CGN is offline
Rep: 121 Posts: 547
It can be done you need to have a reference the same way you will do on a drafting paper where at least you know how long, how high etc...is not exactly the same but in principle you shouldn't have much trouble "sketching" in a 3D software like rhino or prosurf, at some point they all need some input but once you have the hull done hull calcs are few clicks away (see rhino and rhinomarine or Orca3D)
check this demo on how to do a canoe using solidworks similar technique works for other 3D software Rhino, Prosurf.
http://www.youtube.com/watch?v=GS31uJczzvo
This is another good example using solidthinking,
http://www.youtube.com/watch?v=hkrZdneJDz4
Old 12-17-2008, 12:22 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 316
sgcc;
I think you can accept cad in your design work more easily if you start learing autocad frist. Autocad is nothing but like your pen and paper, here your mouse is the pen and the pc monitor is the paper. So i think the frist point is you should try 2d cad frist before 3d.
And ofcorce if you can learn autocad good; then you can go to rhino very easily.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 01-09-2009, 07:10 PM
ROO ROO is offline
Rep: 10 Posts: 31
Hi,
Try DelftShip free version (the Pro is only 150Eur), its quite simple to use, it comes with a default hull, so you dont have to create a hull from scratch, you just drag the contol points to the desired locations. Or you import a boat or yacht and set it up in the background and drag the contol points to the hull outlines. It comes with a wealth of hydrostatic data including an auto fairing (Pro version) and auto prismatic coefficient (all versions) and if you have any problems just post it on the DelftShip site and one of us will help you if you need it.
Design Software? Neverbehind Software 14 03-15-2006 05:09 AM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 01-01-2006 12:40 AM
Design Software needs Millar time Software 9 08-29-2005 11:22 AM
Design software RockReeve Boat Design 1 02-09-2005 09:31 PM
Why Use Design Software Wynand N Boat Design 17 12-02-2004 03:08 PM
