Old 08-29-2007, 04:11 AM
AlexDim AlexDim is offline
Rep: 10 Posts: 7
Lofting a ship tank with rhino
Hey. I have a dxf file of a tank I would like to Loft. I keep getting some holes in the surface. Is there any Rhino pro's out there that could give me the steps for the best way to loft this. (or any other way in order to make this a surface).
See attached file.
Thanks for any help
Alex
Old 08-29-2007, 08:46 AM
snakefeet snakefeet is offline
Rep: 10 Posts: 24
Alex,
I see what you're trying to do but I wouldn't use the loft command for it.
I would use polylines and splines to reproduce the edges of the various planes, then build new surfaces from these edges. There are plenty of sharp corners to snap to, so the edge curves should be pretty accurate. In fact, if you trace the top surface and extrude this curve downward, your vertical surfaces are done. Then use the same curve to trim back a rectangular surface and the top is made.
Trace and trim the bottom surface. Then a two-rail sweep, a few "surface from edge curves " and maybe a curve network, and the outboard surfaces will be done.
Cheers,
Chris
Sorry, I left my witty sig in my other newsgroup.
Converting water tank to Diesel tank steve vilah Boat Design 23 06-25-2007 07:13 AM
Rhino tutorial for superstructure of ship pavel915 Software 7 12-29-2006 12:38 AM
Free!ship for hull design how much advantage over Rhino? Splint Software 1 04-10-2006 12:41 AM
Bait tank/ holding tank fabrication question searaytuna Fiberglass and Composite Boat Building 20 11-17-2005 04:56 PM
Rhino lofting newbie... henrikb Software 8 10-05-2003 01:36 PM
