| Loads Does anyone know how to calculate loads of a machine gun located in the weather deck? |
| You get the recoil specs from the arms manufacturer. |
| i know that. but i need to calculate the response ot the structure(weather deck). I dont know how to do that (which softwer etc) |
| Wouldn't one do that with "ordinary" maths such as this: http://en.wikipedia.org/wiki/Moment_%28physics%29 http://en.wikipedia.org/wiki/Torque And then plug in the different forces on those "levers" or "arms" if you want? I mean, after you get the recoil specs from the manufacturer. It might be the long way around, but at least you can then do it with a piece of paper and perhaps a small calculator. |
| Just make sure wind doesn't blow it to the sea. That's the biggest load to consider... And use engine mounts (rubber/bolt kind) to damp the noise going under the deck.. |
| Mast Compression Loads | yades | Sailboats | 26 | 08-09-2009 05:49 AM |
| loads on sheets | swissboat | Sailboats | 4 | 05-15-2006 04:16 PM |
| dimensions and loads of F-3 riggs | josch | Sailboats | 0 | 02-16-2004 02:56 PM |
| Sail loads | laura | Sailboats | 8 | 11-22-2003 03:32 PM |
| Grounding loads... | ErikG | Boat Design | 6 | 11-03-2003 08:36 AM |
