| Lines plan from Rhino Hi I've been reading some of the excellent threads for a while and decided it's time to jump in as I have a specific problem.I want to output section lines from Rhino to dxf/dwg. It is a small craft (2.5m) and a builder is going to make a prototype by cutting the sections from 50 or 100mm foam sheet in the old bread and butter stylee. This means there are quite a few sections - making the body plan unreadable. I've used "Slicer" to create the sections, but they all end up on one layer. Is there a way of "slicing" each section to a different layer? Alternatively I can select each section individually, do "Make2D" to place it on the Top View for output to DXF, and then move this 2D version to it's own layer each time. This is ideal, as then each section will be on a different layer in the dxf as well... except that this is taking an eternity. It's alright for this one, but if I have to do this a few times as we make changes, it's going to drive me round the filleted edge! Can it be automated (i've never used macros or Rhino Script so I have no idea if it can be done?). Any advice would be much appreciated - I'm sure I'm probably doing it all wrong! |
| Andy Great idea, it would be nice if Slicer could do this, but a script for Rhino would be cool. Gary
__________________ "The hand feeds the mind." Weston Farmer |
| Anyone know of a good tutorial/book for scripting in Rhino? Andy |
| sections to different layers with phaser Hi, I bought phaser last summer and it came with something called sections, which I thought was the same as slicer... Anyhow you can save the sections (sections, buttocks, waterlines etc.) all one layer, each on separate layers or on layers by type (all sections on one layer)... Works pretty well! Might just need to get the latest version (in demo of phaser I think...) Cheers, Dave |
| Andy - the cheapest, easiest way to do it, at the expense of about 5 minutes of your time, is to create all the layers you want, then change each curve to its correct layer. Simple, efficient, no add-ons, no scripting. ![]() Steve "cheapskate" |
| Hi, slicer, gives you the option to save buttocks, frames in an specified layer. i'm using RhinoV2 and i can send all sections to any layer. |
| I will check at home tonite if you can save each of the frames in a layer, like....section x in layer Fr01....section xx in layer Fr02...etc.. |
| If you use slicer somehow the program seems to know what sections were made and seems to delete them if you delete/change the information in the dialog box even if you move them to another layer... might want to copy them to another layer as if you update things they might get moved back... Sorry I'm not certain of what I'm sayin'... I haven't completely figured it out, just thought I should mention it. Regards, Dave |
| I have this option "each section on it's own layer" for the slicer plug-in, but the layer name shows up as: Section 1000.00, Section 1500.00, etc.. you can't change this ones to be something like Fr 01, Fr 02 etc..., but at least each section can be created with it's own layer name, all this apply for all cuts and section for the boat, this is using the slicer "plug in", or sections. |
| Duhhh.. CGN - thank you very much, that's exactly what I am looking for! OK, I feel a bit of a donkey now, sometimes it pays to look doesn't it? So you'd have to rename the layers if necessary, but it's not the end of the world!I've also just discovered that you can select all your newly created section curves on separate layers and then when you "Make2D" you can choose the "Maintain Source Layers" which places all the 2D curves on it's own new separate layer called "<original layer name> - visible". Perfect! How cool is that? It took me two hours to separate them all out manually yesterday - this has just taken ten minutes to do it again, including changing all the layer names. Thanks again for your help. Andy |
| Dave Thanks - I'll remember that. It could also be a useful feature if it means you don't have to re-create the curves and delete the old ones if you change settings. |
| Finally.. thanks cgorton, I've just had a look at the tutorial: http://www.rhino3d.com/tutorials/vb...RhinoScript.pdf It's seems to be well written and easy to understand. |
| By the way, when you export to dwg or dxf there is an option to project to cplane. So, you really shouldn't need to Make2D. Once your stations are set up in the sections tab, you can change the hull surface and then use the section command again. It will delete the previous stations and redraw new ones. Select them all and export as dwg, project to cplane. Cheers, Craig |
| Craig I've just tried it - works a treat. I'm a happy man... Cheers, Andy |
| KB from lines plan | ivansalasj | Boat Design | 3 | 03-25-2005 06:34 AM |
| Lines plan to 3D hull form in shipconstructor. | Emil_h | Software | 5 | 07-25-2004 11:13 AM |
| From lines plan to 3d hull form | ivansalasj | Software | 13 | 07-23-2004 10:53 AM |
| lines plan development | fede | Boat Design | 4 | 11-23-2003 07:30 PM |
| lines plan for cal 2-29 | trimhorn | Boat Design | 0 | 06-20-2002 02:45 PM |
