| lines plan Can I change the lines plan in autocad? I want to lengthen or widen the hull, what is the best procedure ? |
| I don't know exactly what you intend to do but have you can convert to blocks and then modify the X, Y Z scales. Then you can EXPLODE the blocks to have the individual entities. |
| best is, make a 3D model from your lines and then lengthen or widen the model using rhino or maxsurf or other softswares and recreate Lines . If u dont want to create 3D model it will be hard to lengthen or widen because you have to work through control points,and there may be a lot of control points you need to move to produce a fair lines again ,, ty
__________________ DAre To DreAm |
| This may sound dumb (or discouraging), but the best way is to know beforehand which consequence that has. Then decide about the way to draw it. Regards Richard |
| Thanks, Rhino is the best solution but I do not know the commands to modify the lines plan in autocad, how do I convert the block and change xyz? |
| Follow the following steps - capitals for command names - (the results will depend on how your hull is defined): - if your lines drawing is defined as 3D objects BLOCK name the block with a coonvenient name select all objects in the drawing select 0,0,0 as your base point click OK INSERT put the block name select 0,0,0 as your insertion point put the desired xyz scales click OK EXPLODE select the inserted block you should have the lines modified now - if your geometry is defined by horizontal (waterlines), vertical (stations) and longitudinal (buttocks and profile) sections you shall apply the previous process to each projection. Hope I was able to explain... Regards. Rodrigo |
| thanks, I will try to follow the procedure |
| IMOCA 60 lines plan | Chris Cooper | Sailboats | 6 | 12-31-2009 12:26 AM |
| About ship lines plan | nguyenthanhnghi | Boat Design | 4 | 10-29-2009 11:18 AM |
| Lines Plan | builtinpieces | Boat Design | 3 | 10-28-2009 12:14 PM |
| KB from lines plan | ivansalasj | Boat Design | 3 | 03-25-2005 06:34 AM |
| lines plan development | fede | Boat Design | 4 | 11-23-2003 07:30 PM |
