Old 09-27-2010, 02:45 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
Lines breaks while using "make2d" command in Rhino
I faced this problem often. When I use make2d command in Rhino sometimes the lines are broken and distorted. I wonder why this happens. Is there any solution of this?
I have attached one file which shows that problem.
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 09-27-2010, 05:43 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Use "ProjectToCPlane" to obtain a 2d version of the curves. You may have to rotate and move the curves to your desired location. I tried it on you example and the curves projected on the CPlane were not broken.
Old 09-27-2010, 10:57 PM
pavel915's Avatar
Rep: 154 Posts: 319
Thanks DCockey for the help,
Actually I am also habituated with "ProjectToCPlane" command, but sometimes I saw that,it also shows that kind of error.
Thanks again,
Md. Al-Amin Pavel
Albert Einstein
Old 09-30-2010, 01:54 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
Hi Pavel,
Yes, As DCockey says, use the ProjectToCplane command if you want each curve to be drawn individually. Make2d will hide curves which are aligned with each other in the viewport you are creating the drawing from. It assumes you will be making a drawing which will not require each line to be individual. It is similar to drawing by hand in which case you would not draw over each line with your pencil because it is unneccessary.
shouldn't optimized designs be "salt" OR "fresh" water? Squidly-Diddly Boat Design 4 09-14-2009 01:17 PM
16-18' "Sit-in" Planing Monohull ("Trapwing") Doug Lord Sailboats 124 04-23-2009 05:14 PM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 10:56 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
3D "persons" for Rhino modelling Vibtor Software 8 09-29-2004 07:17 PM
