Old 11-05-2010, 03:20 AM
Brian.Lin Brian.Lin is offline
Rep: 10 Posts: 21
knuckle point in rhino
Does Rhino can define a control point as knuckle?
if yes, how to do it?
thx.
Old 11-06-2010, 11:30 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
For discontinuous slope (aka kink or knuckle) in a degree 3 curve insert two additional control points, one on either side of the control point you want o modify. Then drag each of the added control points to the control point you want to modify. Use "Osnap" with "Point" on so the control points snap together when you drag them.
If you just want discontinuous curvature but continuous slope follow a similar proceedure but only add one control point.
Same proceedure for surfaces except you insert rows of control points and then drag the control points corresponding to where you want the kink.
not sure what I'm going to do at this point Boston Open Discussion: All Things Boats & Boating 143 12-18-2010 07:08 PM
Point me in the right direction Kaptin-Jer Diesel Engines 11 03-03-2008 08:53 PM
how to insert point to a chine Ahmed Wahab Software 5 07-22-2007 02:46 PM
Can someone please point me in the right direction? eitanwaks Open Discussion: All Things Boats & Boating 7 05-17-2006 08:07 AM
Hull from point cloud Wenc Boat Design 8 02-10-2005 07:19 PM
