Old 05-26-2006, 11:10 AM
JustinD JustinD is offline
Rep: 10 Posts: 4
KN values in Hydromax
Hello,
here's my problem,
I am producing GZ curves in Hydromax from the loadcase windows and I then calculate the KN values from the displacements and vcg's and use these to get the new GZ in Excel (GZ = KN-KGsin()). I am wondering is it possible to combine the KN values in Hydromax to get GZ curves because I would like to use the Criteria available to see if the GZ curves are right without having to do it manually.
Thanks,
Justin
Old 05-26-2006, 11:14 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
GZ2 = GZ1-(shift*sin(angle)) where "shift" = the change in VCG
Old 05-26-2006, 11:32 AM
Rep: 10 Posts: 4
KN values
That's great Sail Design but it doesn't answer my question.
Thanks anyway.
Old 05-26-2006, 04:19 PM
SailDesign's Avatar
Ah, well - can't blame a chap for trying
Obviously you have to know Hydromax to understand the question..... Hope someone gives you a good answer.
Steve
Old 05-27-2006, 05:48 PM
Rep: 206 Posts: 391
If you want to compare a GZ curve calculated with the Hydromax Large Angle Stability analysis mode with on derived from a set of KN curves, the easiest way is to copy the data into excel and graph the two curves.
Hydromax doesn't apply stability criteria to KNs, as if you know the displacement and VCG, you are always going to get a more accurate result using the Large Angle Stability analysis to calculate a specific GZ curve.
One of the reasons that the direct calculation of the GZ curve is more accurate is that it accurately calculates the effect of the height of the VCG on longitudinal trim. This effect is lost in the KN analysis as the VCG is assumed to be fixed when calculating the KN values. This effect is genrally insignificant in large ships, but can be important in smaller vessels.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 05-28-2006, 10:00 AM
Rep: 10 Posts: 4
KN values
Thanks Andrew,
I am analysing stability with fishing vessels and therefore I will use the KN values as all the stability booklets I have seen for fishing vessels use the KN values.
Thanks,
Justin
Old 05-28-2006, 09:33 PM
Rep: 206 Posts: 391
Justin
That's the problem with stability books, if you want to calculate a GZ curve for a specific loading condition then ideally it should be calculated directly without using KNs as an intermediate step. For the vessel's master however, they need to be able to calculate a GZ curve for a non-standard loadcase, so the KN's are provided to allow him to do so with a minimum of effort. Trouble is, the two methods can produce different results, particularly for shorter, beamier vessels, due to the simplifying assumptions implicit in the KN calculation.
This is just one of the many contradictions that comes about due to the need to simplify calculations (using free surface moments to calculate corrections for VCGs is another example) so that they can be performed on board a vessel by a person with a pen, paper and simple calculator. Maybe one day stability books will be in the form of a simplified version of Hydromax running on a PocketPC, then we won't need to dumb down the calculations.
regards
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 05-31-2006, 05:36 PM
Rep: 1729 Posts: 2,462
Originally Posted by Andrew Mason
Justin
regards
Andrew
Andrew
That sounds like a really good idea.. , if they ran on a laptop would be ok since they are inevitably aboard these days.
Mike Johns.
Maxsurf 9.52 + Hydromax 8.5 jaoji72 Software 1 10-21-2005 09:51 AM
Hydromax - moment wenc Boat Design 6 02-09-2005 11:52 AM
Hydrostatics... with hydromax ivansalasj Software 8 12-14-2004 07:15 PM
Help me! (Re: Hydromax) kreg Software 6 06-11-2004 04:55 AM
