Old 09-09-2003, 04:48 PM
max max is offline
Rep: 10 Posts: 23
keel and rudder design
Hi there,
I´m searching for a software to calculate keels and rudders.
I saw a programm called wings in the net but wasn´t able to run the trial version with windows 2000 nor with windos 98.
Has anybody got experiences with this programm or knows similar software or has a trial version wich is ok ?
Thanx,
Max
Old 09-10-2003, 10:53 AM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Past experience dictates that analysing foils in 2D is all very well, but the real world has other ideas. You can find just the right section from the puter for max lift, low drag, etc, but if the 3D flow is erratic it can, and probably will, be a complete waste of time.
Don't ask me why I know this - please!
Steve
Old 04-26-2004, 06:21 AM
Goodwin Goodwin is offline
the naval architector
Rep: 10 Posts: 6
Originally Posted by max
Hi there,
Thanx,
Max
I've got the same with wings/windows xp
and am also searching for such software.
If you can find anything can you pass it throug??
TNX, S.
Old 04-26-2004, 07:17 AM
nico nico is offline
Rep: 52 Posts: 186
I think a good aerodynamic book would be best. Learn the theory and write spreadsheets or program when needed.
____________
Nico
Old 04-26-2004, 09:57 AM
13j
you can this;
http://www.hanleyinnovations.com/
Old 04-26-2004, 10:34 AM
redcoopers's Avatar
redcoopers redcoopers is offline
Member
Rep: 40 Posts: 54
If you want your own section, I'd recommend xfoil (which includes viscous or inviscid calculations): http://raphael.mit.edu/xfoil/
It's only 2D, but just like posted before, it's terribly difficult to worry about 3D effects. However, most people assume that a wing will only have 3D effects at the root and the tip. If your keel is bounded by your hull at the root, and you have a really big bulb at the tip, I'd just make the assumption that your keel is an airfoil, and not a wing. If you don't have a bulb, or it is not big enough, you just need to remember that the effectiveness of your keel will be reduced because of an induced vortex.
I'd also get a book published by Dover: Theory of Wing Sections. This book is important because you can find what's called a "drag bucket" for low Re numbers for a given section. Designing a keel correctly to fit the drag bucket will be a really big improvement.
-Jon
Old 04-26-2004, 07:43 PM
Chris Krumm Chris Krumm is offline
Registered
Rep: 10 Posts: 92
Try the site for XFLR5 for a graphical user interface to XFOIL for 2D foil design. It's much easier to use than XFOIL itself, and uses XFOIL's code. Inverse design routines have recently been implemented. The download is free and source code is available if you're interested. Be sure to download the foil library as well.
http://mapage.noos.fr/xflr5/xflr5.htm
Chris Krumm
Tandem Keel...? Lew Morris Sailboats 27 06-01-2007 04:18 PM
Keel : Rudder Length Alixander Beck Sailboats 54 11-30-2005 10:42 PM
Keel, bulb and rudder design ivansalasj Sailboats 5 02-06-2005 12:42 PM
Warped plane vs constant deadrise Willallison Boat Design 56 12-11-2004 11:14 AM
rudder size for long keel 50ft WLL ongolo Boat Design 0 11-02-2003 02:26 PM
