dalebirrell
- Joined
- Nov 19, 2009
- Posts
- 25
- Reaction score
- Location
- Strathclyde Uni
Wandering if anyone can help...
I've been trying to use Javafoil to calculate lift and drag coefficients of a NACA 63-412 section and been having a bit of a mare.
I've taken section data from Abbot and Von Doenhoff's 'Theory of Wing Sections' and Im trying to get Javafoils results to agree with that of the books tunnel test results. For a 0012 section, the results agree relatively well, but if you try the 63-412 section, the numbers aren't close and the results don't even make sense. (Apparently the foil will create positive lift coefficient at negative angles of attack.)
Does anyone have any idea why Javafoil doesn't like this section?
If you are a Javafoil user, you can try it in a matter of seconds. The 63-412 data can also be found here -
http://www.teknologika.com/mothblog/hydrofoil-sections/
you can just copy and paste.
I've been trying with a Reynolds number of about 0.52x10^6
Cheers
Cheers
