Old 07-20-2006, 06:10 PM
AstroTux AstroTux is offline
Rep: 10 Posts: 15
Intriguing "problem" with FREEship
Hi,
I've started to design a hull in FREEship and encountered a rather interesting problem. I altered some of the points at the stern of the hull, to make the sides of the hull at the top more vertical. tWhen I went to run the Design Hydrostatic calculations on it, it returned that the hull was not submerged!! This slightly defies the laws of physics IMHO. Why is this? User error or bug? Interestingly, some of the figures that move dynamically as you move points around disappear when this happens, too. It seems it doesn't like have the rear of the hull as level. The file is available on request.
Screenshots attached.
Best regards,
Robin.
Old 07-20-2006, 06:19 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Check where your waterline is relative to those points, and make sure there's no opening between stern and centreline (ie, all points on centreline have y=0). If a leak point drops below the waterline, it's impossible to compute hydrostatics data.
Old 07-20-2006, 10:23 PM
lazeyjack
I encountered same Prob, Marsh
mind you I ALWAYS have problems
latest is trying delete control points in Rhino, highlight, press delete, nothing happens
You know I could have built a boat whilst I fiddle with CAD
Old 07-20-2006, 10:27 PM
Rep: 10 Posts: 15
Hi,
(I'm sure I already replied to this thread a minute ago???)
Thanks for mentioning about checking the points relative to the waterline! If you look at the stern of the hull (closest to you in the perspective view) you can see that the open end of the hull is below the water line. How do I close this off??
Best regards,
Robin.
Old 07-21-2006, 03:47 AM
Windvang Windvang is offline
Yacht Designer
Rep: 65 Posts: 156
Originally Posted by AstroTux
Hi,
Best regards,
Robin.
See
http://boatdesign.net/forums/showthread.php?t=12769
Old 07-21-2006, 07:50 AM
marshmat's Avatar
Make a transom. To do so: Ctrl + click on the aft edge of the hull. Edge > Extrude. Extrude it either vertically or transversely, then set the coordinates of the new points to where you want them. Often if I want a flat transom, I will collapse all its interior edges and points, so that it's not curved.
Old 07-21-2006, 07:55 AM
marshmat's Avatar
So could I.... but for me at least, fiddling with CAD is free, while building a bigger boat would cost thousands. And the university keeps taking my thousands. Grr. Ah well, can always dream....
Working on a 12.5m cat of my own right now. 10 t disp, target is 20+ kts with 180 hp. Might actually build something like it in another 10 years, when I have a real job....
Old 07-21-2006, 03:23 PM
lazeyjack
well I could give you a REAL job
I,m thoriughly sick of this, Id pay you to do it, not a lot but?
Old 07-23-2006, 11:56 AM
nero nero is offline
Rep: 112 Posts: 624
Hang in there lazeyjack! It will start making sense soon.
Old 07-23-2006, 03:16 PM
lazeyjack
ok mate thanks for farm stuff, sorry have not written will call, get bogged down
35' Henriques Maine Coaster "tailwalking" problem on a following sea. dkolb1 Powerboats 11 07-12-2006 05:55 PM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 10:56 PM
Problem with diesel "kill" switch! broadsword Propulsion 3 03-16-2006 08:01 AM
"Freeship" hydrostatic stats analysis of three ships jedclampit Software 17 02-23-2006 08:28 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 02:03 PM
