Old 06-19-2004, 05:13 AM
kreg kreg is offline
Rep: 10 Posts: 16
These are test render;
Could you advice if there are some mistakes?
I noted that in the last america's cup , the designers have given particular attention to the shape of prow, but i didn't understand how the prow can increase the speed.
Could you give me some advice to make my prow better and speeder?
Thanks for your time.
Old 06-19-2004, 05:20 AM
Rep: 10 Posts: 16
ps:
Lbg=20,204 m
Girth Component (G)= 1,912
Freeboard at FGS= 1,501
Freeboard at Amidships=1,293
Freeboard at AGS= 1,232
Weight of Yacht (W)=23974,937
Draft=4,1
Lwl=18,168
Beam wl=3,613
WSA=67,905
Max cross sect area=2,665
Waterplane area=47,472
Cp=0,482
Old 06-21-2004, 09:50 PM
Rep: 206 Posts: 391
Kreg
Nice job.
My undertanding is that the bow shape on AC boats is an attempt to get a long static waterline and a reasonable overhang to increase the waterline length when sailing, while maintaining a low LBG.
The long spoon bow gives up too much static waterline length for a given LBG, while a plumb stem does not increase its waterline length when sailing upwind at speed. The currrent AC bow shape is a compromise between those two extremes.
It may also be easier to have a high prismatic coefficient with the current bow shape, I think it is difficult to get adequate volume forward with the older style spoon bow.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 06-22-2004, 02:29 AM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
I agree with Andrew. It seems that the designers have placed the second "knuckle" in a way so that the waterline length is increased when the yachts heel.
Regarding the prismatic coefficient, I think that yours is a bit on the low side. I don't know the CP of the ACC yachts, but I would probably increase it to about 0.53-0.54. As a starting point, you could use Gerritsma's formulas for resistance and calculate the optimum CP for your expected speed.
Old 06-22-2004, 02:45 AM
Rep: 206 Posts: 391
My guess is that he has calculated the Cp with the appendages attatched, rather than just the canoe body.
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 06-22-2004, 04:55 AM
Rep: 10 Posts: 16
yes, in fact, the cp for canoe body is 0.55; Can you tell me where i can find the Gerritsma's formulas?
thanks.
Old 06-22-2004, 07:05 AM
Yacht Designer
Rep: 389 Posts: 507
It is common practice to use the cp of the canoe body - 0.55 sounds about right to me.
Gerritsma's formulas can be found in "The Bare Hull Resistance of the Delft Systematic Yacht Hull Series" by J.A. Keuning et al. You can download this paper (and a lot of other interesting stuff!) at http://www.sailboat-technology.com - go to "Online Articles"
Old 06-22-2004, 09:00 AM
Rep: 10 Posts: 16
ok, thank you very mutch sorenfdk
Information regarding recycling of wastes generated from small fiber glass boatmaking sivaramakrishna Services & Employment 5 02-03-2009 05:18 PM
Information Required... sivaramakrishna Materials 5 04-22-2005 04:02 PM
Information Reqested Regarding Fiber Glass Boat Manufacturing sivaramakrishna Boatbuilding 9 08-25-2004 09:16 AM
study information drascombe yachts dyanemaniac Boat Design 2 02-13-2002 04:39 AM
Boat Interior Design information Boat Design 1 10-02-2001 05:57 PM
